its either you need a new charger (assuming your charger is broken) or you need a replacement on your charging port (it can be costly, try replacing a new charger)
Its almost like that is 'yet another way' to get us to Buy again...and again...and again.
Mine and the Girlfreinds do the same thing. I have to 'Lean' my plug on something to get it to work.
For this i am Resisting the urge to 'Buy another'.
Bring back the Good Old Days, where 'Quality workmanship' meant something.
Good Luck with it though.
That symbol usually indicates the battery isn't charged or charging. It could be a connection problem, a charger problem, or a battery problem.
If you have an extra wall charger, try that first as they don't always last forever. Make sure the plug that connects to your tablet looks clean and not corroded.
If it still won't charge, then chances are the battery needs servicing to make sure the connection is OK or the battery just might need to be replaced.
Get a multimeter and test the power charger , if its working then you have a broken power ingress point on the tablet so its hosed , be cheaper to buy a new one , if its the psu you can get replacements on ebay for less thanten euros
If the end of the charger broke off inside your nabi, it will be difficult, but you can get it out. Ideally you still have the broken piece. Superglue the end, put it back in and let it set, then pull it out quickly. If you don't have the rest of the broken piece, you can use something like a toothpick or a cotton swab with the cotton tip removed. Check out YouTube for videos on this. If your charging cord just fell apart and nothing is broken inside your nabi, just buy a universal charging cord. Make sure the tip matches the one you broke. Amazon is a good place for finding these. It will still charge your device.
you can charge it through USB from any laptop or multichannel charger, if it's 7 inch or 10 inch you can use any charger for car toys for kids it will work fine.
You can go to CD-R king to buy a replacement charger but bring your unit so they could check the adaptor needed and the required voltage. Or you may go to the place where you first bought your pc tablet and ask them to buy a new charger. If there is none available, ask them where can you buy the charger, they would certainly give you the information.
