Trying to by pass all the wires an wire harness need help coil has 2 wires well the plug wire......... has a vary weak spark now
Hi, I do a lot with these bikes, I think if you are getting a weak spark there is a couple things to check. First, do you understand how it builds the power to create the spark? The magnet in the flywheel has to be very close to the magnito or coil, if the gap is too much it will cause a weak spark, if the magnet is weak, weak spark, if the coil is shorting internally, weak spark. If the plug wire is damaged, weak spark. I hope this helps you.
Thanks for the input I got a new plug an just orders a new coil . That's my start other then anything else I don't have a clue I bought the bike cheap an was told it's A 49cc two stroke ..... next question would the cdi box have anything to do with the fire ?
