Checked the water fill valves.
SOURCE: LG Tromm has the error code LE what is it?
unplug the machine or turn power to outlet off. wait five minutes. turn all back on should solve problem
SOURCE: "FE" error code; won't stop filling
Hello Sheri Tucker,
The "FE" code is referring to a bad or malfunctioning water valve. The machine continues to fill because the solenoid on the valve inside the machine isn't closing to stop the water. The valve should be inspected and/or replaced if bad. This will require some dis-assembly, if washing machine repair isn't something your comfortable with then a service call is the best bet. If you are going to try and inspect yourself please make sure you unplug the machine before starting any dis-assembly. Hope this helps.
Thanks,
edgin96
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
SOURCE: "UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
Try adjusting the load size, and make sure the unit is level.
SOURCE: Error Code LE on LG Tromm WM2277HS
Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective
SOURCE: LG Tromm WM0642HW washer leaking water!
I also had water leaking from under the washer during rinse cycle only. I tilted the washer back far enough to get under it and found that the drain hose, part # 4738ER1002 had been punctured by my wifes bra underwire. Super easy to replace and the part is only about $18.00 on ebay.
