Checked the positives and negatives from amp to speakers
SOURCE: Front speakers only produce static
The amps are on each of the speakers. There is a place in Florida that will fix them for around $85.00 each plus shipping. I put a sony unit in mine and replaced all of the speakers with the kicker ds series for less than fixing the bose system.
SOURCE: Speakers/Stereo may be shorting out
You will need to remove the stereo. Some of them have four holes that you have to put either the tools or long thin screwsdrivers or nails into to pull it out. Others have tabs around the edges that have to be bent down in order to come out. Then you will want to look at the wire harness to see where the short is. See if it can be glued or soldered back together
SOURCE: 2004 Tahoe - speakers are crackling.
if your truck has bose the you probably blew the bose amp and will need to bypass it now to prevent speakers from making noise.
SOURCE: dodge dakota 1993-- thewiring diagram
use a AA battery and touch speaker wire 1wire on positive other on negative
look at speaker if cone come out or up wire to positive end is positive
if speaker cone goes in or down the wire on the negative of battery is positive
SOURCE: passenger side speakers don't play sound
same thing is happening to me and i replaced the door speakers and still nothing! I read the factory radio sometimes shorts out so you need to replace it and thats what i'm gonna do. I'll let ya know. Good luck!
