Comtrend Adsl2 Ethernet Router Model: Ct-5072t Logo
J
Jonathon McCoy Posted on Jan 25, 2015
How do I ix my adsl2 comtrend modem when the internet light will not come on
A
Anonymous
If internet light is off, its not connected to the net. Check all connections. If OK try pressing and holding the rest button for 30 seconds.
Internet will not go through my comtrend CT-5072T modem
Need a bit more background on this.
Did you just go out and buy this device and hook it up to the phone line ?
Are you using ADSL line Filters ?
Did you ring your internet service provider to guide you through setting up the account settings in the modem ?
How are you connecting to the device to your P.C ?
No internet light
Try resting it by holding the rest button in for 30 seconds.
2helpful
No ip on comtrend ar-5381u, will not connect to internet
DO NOT INSERT A PAPER CLIP TO RESET THE MODEM! unless you know how to reprogram the router, this includes having complete knowledge of ALL the settings required by the ISP AND having your username and modem password (modem authentication passwords are not usually provided to the customer) Doing a "hard boot" will only return your modem to factory settings
Comtrend CT-5621T reset
Most routers are the same. admin/admin or admin and no password.
Where can I get a user's guide that shows details for the configuration of a Comtrend CT5621 ADSL2 router with a LinkSys wireless router.
From the ISP (this is a specialized router for DSL only.
Call your Internet Service Provider.
Asymmetrical Digital Subscriber Line (ADSL
I have a comtrend ADSL2+Ethernet Router hooked to my desktop Pc and a G-Wireless Router made by Belkin.According to the tech I should be able to connect these two to use my Laptops, but any way I've tried...
You dont need a Belkin Disk to set up - this can be done manually you can get a manual from this site http://en-us-support.belkin.com/app/product/list/q/routers/ select G in the first dropdown and then your model - theres two to choose from and then then the version
you have a choice - you could change the comtrend router to just use the modem - bridged mode - they have a few different routers see here http://www.comtrend.com/links/i$residential-adsl2-modem-router$product.htm so not sure which one you have if you can bridge to just use the modem then connect tothe Belkin and all PCs should connect to the Belkin
OR you can connect two routers together Leave the comtrend router set as it is -
Set the IP address of belkin router to same subnet as the comtrend. Depending on the DHCP range of the comtrend router - set the IP outside this range - so if comtrend is set to give an ip of 192.168.0.2 to 192.168.0.100 - set the belkin to 192.168.0.254 Disable the DHCP in the belkin.
Connect the comtrend LAN to one of the Belkin LAN ports - you may need to use a crossover cable. On the belkin the WAN port will be left unconnected
I have a comtrend CT5071T which the phone company had for my internet which is not wireless. I have purchased a comtrend wireless adsl2router which I wanted to use. I called the phone company and they said...
If you want to connect to the wireless network you can connect one of the 4 ports to the ADSL modem, this will allow the device to switch between the Wireless network and the wired network. You could also purchase an access points instead of the router but the result is the same, is just that you won't use the routing capability of your Wireless router.
Top Comtrend Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Comtrend Computer and Internet Expert? Answer questions, earn points and help others
