Kenmore HE2 Plus Front Load Washer Logo
A
Alex Bennett Posted on Jan 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore HE2 Plus fronload washer is showing F- as an error code. there are no numbers in the error code. just "F-" i cannot figure out what that means
Ive tried looking online to find the diagnostics and cannot find anything for error code "F-"
adrian halligan
Level 3:
Genius:
  • Master 1,075 Answers
  • Posted on Feb 11, 2015
adrian halligan
Master
Level 3:
Genius:
Answers
1075
Questions
Helped
278972
Points
3080
Press and hold the power button until the machine resets,then if machine resets, ok. but if machine shows a fault it should give a full fault code.adrian,,,,,,,
Shelby Gensamer
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Feb 03, 2015
Shelby Gensamer
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
14615
Points
48
Can I have the complete Model # so I can get you working again?
5 Related Answers
myredbeemer
  • Posted on Dec 02, 2008
SOURCE: Kenmore HE2 Plus Error Code: F-20
You probably have this solved by now but for others who read this as I did.............
F-20 means
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Hope this helps everyone else as it did me, thanks
Anonymous
  • 878 Answers
  • Posted on Mar 06, 2009
SOURCE: f-26 error message
F-26, is a door lock switch error code. Some things to try; Unplug the washer for 1 minute and see if the error clears. If not, try entering the diag mode by pressing any key except pause/ cancel. Press for 4 seconds and release for 4 seconds 4 times. If entered correctly, all lights should light and the first error should appear. Press the same key to advance through all the errors. When the errors finish. It will start an automatic test mode that tests all componets. The first thing it will test is the door lock. If this fails you more than likley have a door switch problem. Let me know how you make out. Catriver
Anonymous
  • 1922 Answers
  • Posted on Nov 19, 2009
SOURCE: What does code F21 mean on a Kenmore HE2 plus
it stands for longer than normal drain interval,press "pause/cancel" twice to clear, if it returns then look for obstructions in the water drain from the basket all the way to the drain in the house,or possibly it could be a bad washer drain pump
Anonymous
  • 1998 Answers
  • Posted on Jul 18, 2010
SOURCE: my HE2 kenmore front load washer shows a code of
check the water tempreture sensor and connection to it
heres some info that should help ya
http://www.applianceblog.com/mainforums/sears-kenmore/10283-he2-error-codes.html
hope this helps
pdf.gif HE2 Error Codes.pdf
Anonymous
  • 15935 Answers
  • Posted on Sep 18, 2010
SOURCE: I have been trying to run the clean cycle on my
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
F30 shows on a kenmore washer HE2 plus ehat does that mean
That is a dispenser error code. There is a motor on the dispenser and it is not working properly. If you post the model number, I will see what parts are.
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
1helpful
Kenmore H2 PLUS reads F--28 code what does this mean?
The error code F28 means one or both of these parts are bad.
Motor Control Unit (8540135)
Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for error code F28
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
Here's the online repair manual for your
Whirlpool Duet Sport, but its identical to your HE2.
Give it time to download.
On page# 4-20 it shows how to access your MCU.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
My washer is showing a error code of f-28. What does this mean
The F28 error code in most Kenmore models is a MCU (Motor Control Unit) failure or a wiring issue. You did not include a model number for your washer. Without a complete model number I am unable to supply you with anything other than generic help.
1helpful
Error code F-28
It may be that the drain pump is not the problem at all. Error Code F-28 on the Kenmore HE2 means that there is a signal error between the Central Control Unit (CCU) and the Motor Control Unit (MCU)
I have an error code of F-01 on my Kenmore HE2 Plus washing machine. What does this mean and how do I fix it.
Your washer needs to be serviced by a professional. That error code means there is a communication error between the Control Unit and the EEPROM; the CCU needs to be replaced. Check to see if your product is still under warranty.
Refer to page 2 of this service manual:
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208540259.pdf
Alexander
vince
