It's not loading / feeding right, and I'm freezing. Can you help?
SOURCE: purchased a used earth stove mp240 pellet stove
The auger motor is fed through a high temp. limit thermostat. It has a
manual reset on the back of it that you have to press on firmly to
reset it. Open the side panel on the stove and find the wiring. You
will see the thermostat on the back side of the combustion chamber.
Look very closely and reset it.
good luck!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: combustion fan isn't running
Ther is a guy names Murphy that it resposible for that. Go back through the steps you used to change the auger motor and see if maybe there was a wire left out or if the combustion motor is also out. What caused the outage? If a voltage spike, it could have taken them both out. The only other thing I can think of is a main switch somewhere. Good luck...Lee
SOURCE: i have about 1996 country flame pellet stove. when
Need a new auger motor. They have beefed up to a bigger stronger motor
