Power train warning light came on 1st and 2 and gears spluttering got home turned engine off turned engine back on light goes off so went around the block and nothing happened is there a foult
Sounds like the computer and transmission aren't communicating properly, if happens again you should get it checked out it may just need a little reprogramming.Sounds like the computer and transmission aren't communicating properly, if happens again you should get it checked out it may just need a little reprogramming.
the power train comprises the engine , transmission , drive shafts and differentials.
surging on lpg is an indication of the gas converter freezing up in the regulator and needs attention
for other details get a work shop manual for your vehicle as the areas are explained in detail with photos
I assume there's a problem with alternator. Check the grounding to engine, check continuity of a positive wire between alternator and battery. the energizing voltage should be checked as well. Might be the bad connection between battery and vehicle body grounding. Diesel cars are sensitive even in a little loss of connection and rust in the connection points.
96 intrepid lost 3rd and4th gears will only run in 1st and 2nd
no lights or other warnings .car was in cruise at 60 when engine
just went flat out trying to keep to 60 no codes showing any faults
I would take it back to Battery World and let them fix it.
In our days Cars very sensetive to power loss to power train menagment components , may have to do somthing with throttle control.
Get the codes read as it could be anything. The car will run with this warning up until the fault goes to the next level - then it will shut you down. Get the codes read as it may be something small like a sensor or even a bad connection - from the ''splutters'' it sounds like it may be fuel/air based.
hope this helps-good luck.
ello m8,,hows things,,clean out the air filter 1st, change all your plugs mr,try that , if nothing u will need to get the carbs balanced to by a bike shop,mechanic,,unless u have carb gauges,,, itl be easier if they do it,, try these 1st m8,, if no joy come back and il go threw step 2 with yuh,,
Checked all fluids all OK is it a problem
