You should immediately replace the console. That console will just keep getting worse. This is endemic of this brand, however it usually happens a lot further in the life of the unit. When you call Nordictrack have your model number.
Disconnect wifi and boot machine. This works well for a non-internet workout. I had a similar problem--endless looping of the boot up routine--which ultimately fixed itself when I tried updating. I believe they came out with a new update which must have fixed some bug in the system.
In normal operation you put in the key and display should light up. Also there is a reset switch on the frame near the power chord which might be off. Below is link to the User Manual for NordicTrack x7i. I got that info on pg 16.
1) Lube the deck belt, this happen because the electronic system protect the system and shut down.the cause is deck worn. 2) Lube the rollers bearing too. 3) Measure the input voltage motor, if there are the motor need repair. 4) Measure the output voltage board, for input voltage motor, if there are Not the board is faulty. God bless you
