You have a coin or a hairclim or metal part of a zip that is stuck in the filter where the wings of the water pump rotates against it.
Open the filter and try to remove it. Unplug the power first.
Good luck
Bye
The filter on the pump was clean and empty of any debris. I cleaned it any way and put it back. It still makes the same noise.
Hi Steve, Try so to see if there is some parts rattling in between the door seal and the drum. At times buttons or little bits like from a zip could end there.
It makes the noise with the drum stationary on occasions, so the drum can be ruled out I guess. It doesn't make the noise for the first Half hour which is when the pump first kicks in. Each pumping spell it makes the rattling noise on average 4 or 5 times over 1 to 4 seconds.
Cracked it! A 5p coinmust've got past the filter and the pump kicked it up the outlook pipe. Every so often it would fall back into the pump vanes and make a noise before being kicked up the oupput pipe. The 4th time of taking the filter out the 5p coin was there on the bottom below the vanes. Took it out and all is now quiet. Thanks for your help Paolo. Steve
