Why can't my TV find a digital signal when connected to my digital ready aerial? Tuning for digital stations finds none. Does this TV require a set top box? If not how can I make it find and play n
While the TV function finds nothing when I connect an HDMI cable the TV seem is able to display the signal and seems to be working correctly. But of course one can't change the channels. The remote control seems to work correctly. All the menu functions seem to execute correctly. But no matter what I try I don't seem to be able to get any digital channels via the outdoor aerial using any of the tuning functions. I am close enough to the broadcast signal tower.
    New Friend:
  • 11 Answers
Hey, when connect any aerial in the back of the TV make sure you have a look for the name of the connection you use ( Skart,ext1,ext2,usb,hdmi1, hdmi2 etc.) so you can do a search on that extension. if you connect something on Hdmi1 and search on hdmi2 you won't find anything. you have to search on Hdmi1. PS: good luck.
Posted on Jan 24, 2015
SOURCE:
Why cant i get my digital channels
Is your TV designed for digital signals, if not you will need a set top box. Make sure the aerial is in good order and all connections are tight and clean , go into settings on the TV, select digital tuning and press ok , if the TV is in good condition and there is a signal digital to the aerial it will download
Apr 19, 2015 | Element ELCHW402 40 in. LCD HDTV
When I auto scan channels it want find none. what do I do??
Is your TV aerial plugged in. Do you know if it works. Are you tuning the digital stations (you should be. There are no analogue transmissions any longer)
Sep 09, 2014 | Televison & Video
My tv screen says no signal with the coaxial cable hooked up
Sep 09, 2014 | ViewSonic Televison & Video
Hdtv or converter box
If the TV is already hdtv...no. Try reprogramming tv to find hd stations or if receiving signal from outdoor aerial make sure aerial is digital and facing right direction.
Nov 30, 2013 | Mitsubishi WS-65315 65" Rear Projection...
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
I have tried tuning in my dvd recorder in the reset menu, but after the scan process a message appears "Check aerial connection. Help, what am I doing wrong?
make sure aerial is in dvd recorder press functions move down to others press enter move down to setup and enter highlight tuning move right and down to auto setup reset and enter
tou will see a warning message move to yes and enter the dvd recorder will start tuning and a list of all the stations that been found will be displayed after that it will start to scan for analog stations( BEEN TURNED OFF) once finished
picture will be displayed
if no list was seen when tuning in digital stations then make sure dvd is digital
and to check aerial put direct in to didgtal tv and retune tv
Dec 16, 2009 | Panasonic DMR-ES10 DVD Recorder
No carrier signal
Your area TV stations may have already switched to digital. If that's the case you will need a digital converter box. I'd check with your local stations to find out.
Mar 19, 2009 | Orion 19RTLB (Black) 19 in. Flat Panel LCD...
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
Ekse
