Question about HP Pavilion dv4000 Notebook
Hewlett Packard HP Pavilion dv4 back door
Press f8 many times need to reset admin pw
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 55 Answers
If you want to reset the BIOS password remove the computers battery and then open the backpanel and remove the bios battery for about 20sec. If you want to reset Windows admin password this is harder issue -> easy way make a backup and reinstall windows and then restore the backup.
Posted on Jan 28, 2015
SOURCE:
RPFinney
  • 385 Answers
SOURCE: change english to spanish hp laptop
go to control panel, regional languages, languages and keyboards,
Select spanish, put it to the top, save it, your done.
Select the option to put the language bar on the desktop,
then you can switch between languages,
Regards
Richard.
Posted on Apr 22, 2009
SOURCE: How do I disable double-click on an HP Pavilion dv4 touchpad?
Hi there Dublin. I recently bought a HP laptop myself, and I believe I can help your situation, or at least I hope I can. Here's what you do: Access your Control Panel>Click Mouse>Click Device Settings>Click Settings> Click Tapping> Click Disable Tapping. That should do the trick. You are not disabling your touch-pad, just the double-clicking that is associated with it. Drove me nuts for about a day, 'til I figured it out..Hope it worked for your notebook.
Posted on Jun 10, 2009
bob_computer
  • 3153 Answers
SOURCE: HP Pavilion dv4 not turning on
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Posted on Sep 23, 2009
JoAT
  • 121 Answers
SOURCE: hp pavilion dv4-1220us overheating then shutsdown
Sounds like you need to take it in for repairs, clean outs and/or replacements.
This product is known for it's heating issue and power consumption. Maybe the fan is starting to wear out and it's affecting the rest of the system. I would suggest checking the warranty on the system, if it is no longer valid, then I would look for a local tech in the newspaper.
Posted on Dec 15, 2009
Damilare
  • 358 Answers
SOURCE: i have hp dv4-1465dx, how to reset bios without having OS
Was Windows 7 the operating system that came with
your System? If not, What I would advise you to do
is this:
Check HP website to find out if your Laptop supports
Windows 7.
If it doesn't, then I would advise you to
PLEASE change it back to the operating system
that came with your system, or better still, the
operating system that it supports.
The reason is because that is exactly what I faced
two weeks ago....
I changed the operating system for my PC to
Windows 7 ( Even though it doesn't support it)...it
worked fine for a while, then later it started to develop
faults after a while...like stuttering, mouse pointer
moving round the screen, graphics displaying
improperly...etc.
I first thought it wasn't a big deal, so I fixed it by
repairing the drivers, and it worked fine once again...
After using that same crack that you said you used,
I started getting "Multiple Hardware Error"!
It would just Power on, Show HP Logo, Show
Wireless LAN indicator Led ON, and It will freeze
there. I could not even enter the BIOS.
In short ....Now as I'm typing, the system is
with HP Service Centre for they have to change the
Mainboard Outrightly!
So PLEASE, if your system was not specified
Windows 7, use the Operating Systems that it
supports.
Then go to HP Website and download the original
BIOS settngs for your Laptop then repair your
system with it.
But if it is the one that came with it, then let me know
so as to tell you some quick fixes.
Hope this helps you out.
Goodluck and thanks for using fixya!
Posted on Feb 07, 2010
Blue screen on envy 13 admin password prompt with system disabled - CAN YOU FIX HP ERROR CODE 64449838
I can only help with the system admin password (presumed windows). You will have to manufacture a "Password Reset Disk" on another PC or laptop (preferably running same OS - you will need your product key COA number). Instructions on MS website. Also - check your BIOS settings are OK when setting to boot on the password reset disk. That will be F1 or DEL probably on power up.Good Luck.
Dec 21, 2014 | HEWLETT-PACKARD Hewlett Packard...
Cmos reset
u need to open the laptop..i don't advice you to do that if it's the first time..the cmos battery must be disconnected for a few minutes..
Jan 14, 2014 | HEWLETT-PACKARD HP Pavilion DV6-3013CL...
I received this laptop as a gift. it was used and the warranty has expired almost two years ago. I don't have the password to gain access to my entire computer because everytime I try to download anything...
Which os system are you using? when computer is booting continue to press F8 to bring in safe mode then log on as administrator pw might be admin need more info
Oct 22, 2013 | HEWLETT-PACKARD HP Pavilion dv52045dx Core...
Needing to unlock password
Hello.
There is a hidden Administrator account that is created when your operating system is installed. Access that account and then reset your password.
1. Boot your computer and press F8 repeatedly
2. Access Safe Mode
3. Key in "Administrator" in Username, with no password.
4. Go to Control Panel, then User Accounts
5. Select the account you want to reset the password
6. Change the password
Hope this helps
Jun 27, 2011 | HEWLETT-PACKARD HP Pavilion dv7-4285dx...
How do i get the sound on my HP Pavilion laptop to work again?
Well, you need to make sure its not on mute. If its not, then try reinstalling sound drivers. IF this doesn't work, then its probably broken.
Mar 26, 2011 | HEWLETT-PACKARD Pavilion DV4-1275MX Laptop...
I have a HP pavilion a6119h desktop. After downloaded updated and shut down two days ago now it doesn't want to boot up or power up.
Try to start the pc in safe mode (pressing F8 at start up will give you this option) then choose system restore and reset to a date before the update this should fix your problem. PS i dont think id try that update again
Oct 30, 2009 | HP Hewlett-Packard GG041AAABA Pavilion...
HP Pavilion dv4000 Notebook Logo
112 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
