What is the mix ratio for a Johnson outboard motor?
Any Johnson outboard motor built since 1964 requires a 50/1 fuel ratio. Motors built prior to that date require a 32/1 ratio, with the exception of a few fishing motors built prior to 1955 that use a 16/1 ratio.
For minor tune-up. Remove, clean or replace spark plugs. Use Johnson recommened fuel additive and recommended fuel type. Replace lower unit grease. Spray clean carburetor. Check fuel line and filter. check water pump function.
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Any fuel filters? If the fuel line is old I would replace it due to the ethanol in gas. If not that then clean the carburater, high speed jet may be clogged.
i have a 1977 85 hp johnson outboard it started and idiled for about a minute and now i cant get it to fire at all its got good spark possibly not getting fuel but is there anything else i should check
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) mercoutboard motors mercury outboard ... diagram of mariner outboard motors johnson outboardfuel problems ... johnson outboard motors ebay 1996115hp mariner outboard
