You can't. It has an anti-theft device. The days of boosting a car with a couple of wires ended in the 1980s! You have to fix the problem, not find a way around it.
The PassLock system was designed to prevent vehicle theft by disabling fuel to the engine if ... Chevrolet Silverado 1997-2004. Chevrolet Sport Van 1997-2000
REBUILT WITH LIFETIME WARRANTY GM Passlock Anti-Theft VATS module. PART NUMBER 16264985. THIS PART IS OBSOLETE AND UNAVAILABLE AT ...
Rating: 5 Ā· ā2 reviews Ā· āUS$149.99 Ā· āIn stock
Scan transmission module for any codes that may be present to point you in the right direction. These newer transmissions are electronically controlled throuigh various solenoids.
Try the main fuses. I went through this with my car. After spending money on a new battery I didnt need and a new starter I didn't need I found it was a $2 fuse.
1. CHECK ALL FUSES
2. CHECK FOR 12 VOLTS AT SWITCH, IGNITION ON!!!!
3. IF POWER @ SWITCH...ACTIVATE SWITCH WITH POWER ON, CHECK FOR POWER TO DOOR LOCK MOTOR.
4. POWER WILL END SOMEWHERE, AND THIS IS USUALLY YOUR BAD COMPONENT/S
Fixed Problem (it was my van) no power to ignition wire at starter. Replaced Ignition lock cylinder. just worn down. (Delivery van 50-60 starts a day). 160k miles.
