Tried to get info if the water valve is the problem before I take it apart
SOURCE: leaking water coming from underneath
ok there are 2 screws that hold the front panel on. they are at the bottom. take them off then take the panel you can see inside. ckeck hoses.be carefull if you run the machine there is a gearcase that spins if you hit it while its running you can break your arm.
SOURCE: Tumbler Washer drum fills with water when unit is not operating.
yes the water vale is defective it has goten a little piece of sand of something in it and it dont take much replace the valve and the problem will be gone good luck
SOURCE: drum keeps filling with water when not in use
Hi, You will need a new water inlet valve. the valve has stuck open just enough to let water trickle in. Until you can repair it, just turn the valve off at the wall. If you have not yet found your answer, let me know and I will assist you in getting part#.
I hope this helps. If so, please rate my answer so I know how I am doing.
SOURCE: Drum will not hold water when filling or if it
No malfunction in the machine that I can imagine could cause your problem.
There are only two ways that your washer could be losing water, you might have a leak in which case you would know because you would see a mess on the floor.
You might also have the end of the drain hose to low, gravity will cause the machine to drain if the tip of the hose isn't about four feet off the floor.
SOURCE: Frigidare LTF2940FS is no longer filling with
a guy i know had this problem. he had washed a bathroom rug with the rubber backing on it. the rubber came off and effected the pump.
