I have a constant similar problem with my pnumatic nailer. If the construction is similar, flip up the barrel cover, make sure it's not jammed (sometimes 2 nails come down at once).pull back the pressure spring (on nail housung). Remove upper barrel piece for easier acess to the barrel. use something sharp to pry them out.Make sure to oil your barrel regularly. It's less convinient but another way to do it is to bite the bullet and buy a 5 gallon compessor, cord, hose, etc. Dewalt sells a kit at a reasonable price.
Is this a gas cartridge type of nailer? It could be the effects of gravity on the spray nozzle. try pushing down in normal position but dont fire it. quickly move to ceiling then try firing. I am not a fan of this type of nailer as they are problematic and finicky.
SOURCE: nail gun wont fire
First - the air pressure has to be high enough - check the regulator on the tank to make sure it is delivering in excess of 60-70 psi (which I am sure you have already done).
If you have dry fired these guns (i.e. shot them off with no nails in them while you were lubricating them maybe) the mechanism inside could be damaged. I had that happen to one of my nailers (same brand). That was when I learned not to dry fire them...
Since both of them are not working though I would be more inclined to look at the air supply first.
SOURCE: I rebuilt my NR93AC3 because the old body cracked.
is it leaking out the trigger or the top?
Thanks,
Jeff
SOURCE: my paslode angled finishing gun keeps jamming
Hi, heatman101
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
SOURCE: My dewalt cordless finish nail
there is a lock in rear right side (small black rubber thing) us push it back!
SOURCE: When i put air to my gun it has rapid fire and will not stop. How do i fix this
It sounds like either the trigger valve is stuck of malfunctioning. It is item 68 on this diagram. With the toll UNPLUGGED from air make sure the trigger pin is releasing as it should when the trigger is depressed. Obviously do not check this with it plugged into an air line.
DeWalt D51823 diagram
Its not a gas type, its the 'Fly Wheel' type I think its called, just a battery at the bottom of the grip. Tried different brands of pins but all causing same problem.
