Nokia flash file click here select BB5 Support which is shown at the left Taskbar again select 3110c.You can download it from the second column.Good luck
It sounds like your keypad lock (keyguard) is on. To unlock the keypad, press Unlock and then press the asterisk key (*) within 1 and a half seconds. The word Unlock appears above either the "Left Selection Key", the "Middle Selection Key" (4-way scroll key), or the " Right Selection Key" just below the display, indicating which key is currently the "Unlock Key".
Hi, when a keypad does not work on a phone, it is usually caused by dirt inside the keypad area of the phone,you can open the phone and clean up the keypad area.
Sometimes too, as the case may be Chips also can affect the keypad and allows the phone keypad not to function.
There is an IC chip inside that controls the function of the keypad. You can fixed the IC chip inside the phone by replacing the damaged IC inside the phone.
When you replace the damaged IC .i assure soluton tothe problem.
hello friend
as i know that nokia didn't publish their master code,,,,
as i found on internate that it's master code is 123456789,10
but it dosen't work on my phone
go to the repair center and ask for unlock...
or buy dongel your self and unlock programme too then unlock your self gud luck
