Jun Tapia Posted on Jan 21, 2015
Where can i download quma tools for dr9080c plss help me
Pink line in color scanner
Felix Yusupov
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Jan 22, 2015
Felix Yusupov
Contributor
Level 1:
New Friend:
Answers
17
Questions
Helped
4615
Points
32
2 Related Answers
Anonymous
  • Posted on Apr 25, 2013
SOURCE: What does a Red 1 and a Red 3 on the Quma tool
Red 1 and 3 are good! 1 is the home position sensor for the document lift tray and 3 means the top cover is shut.
Steve Garthe
  • 78 Answers
  • Posted on Jan 08, 2015
SOURCE: I have a dr9080c scanner and it does not pick up red or yellow colors, have already adjusted setting, HELP!
Which settings have you tried? Did you attempt to enhance the Red settings? What program are you using?
Each machine has settings built in for color drop out and color enhancement, If you are using the free Capture Perfect software, there is a setting in the where you make the enhancement or drop out changes.
Where is the QUMA tool for the dr 9080 scanner
Quma service tool is on the original driver CD that came w/ the scanner. password is the name.
HOW TO GET INTO THE QUMA MENU
When double clicking on the Quma tool, type in "quma" as the password.
I have a Canon Scanner DR7580 and the wheels are hesitating upon feeding of the document.
The rollers slip if a) the document is slippery or dirty, b) if they are unclean after usage or c) if there is hardware problem.
Try scanning a set of clean sheets, clean the rollers with a damp cloth thoroughly (no solvents pls). Get QUMA tool and check if the rollers are working independently.
S. Mohan
Problem with Canon DR9080C scanner and Capture Perfect 3.0 softwere
Do you have enough disk space? Check if your C; drive has enough space. Normally C: is used as 'scratch area'. Try scanning intoa different location.
S. Mohan, Chennai
old marine
old marine
ZJ Limited
ZJ Limited
