Yeah, check your bearings in the nose and on the back end. check to see that the vanes are all good too. have you added any grease to the orings. sounds like some screw isn't tight causing the wobble and no power, well that sounds like a air flow issue. so if the air in is at least 90 psi and its coming out when you squeeze the trigger and only then. Its good trigger and it has to be the vanes are worn and motor housing dirty,
SOURCE: IR 2135TI repair manual
Go to: http://www.irtools.com/contact/?pro=&cat=&sbu=&formType=ussales
make a Request for schematic, they have always given me great assistance.
