When i oon the above machine.after one copy error code 004-361 coming on the display
Http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/engb.html?associatedProduct=workcentre-7328-35-45-46-built-in-controller
This link should help you. It might also be broken on the other contact end of the drum which will require an engineer.
SOURCE: Error 15 004 45 37888
From the service manual:
15,004.45:
TCD_THERMISTOR_
SLOW
Most likely cause is a failed drum heater. The head to drum gap
should only be checked or adjusted on the Phaser 840. The
Phaser 850, 860, and 8200 have a pre-adjusted head.
In other words, you need to replace the drum heater.
Thanks and please take a moment to rate as fixya.
SOURCE: My error code is 09,038,46:6774 xerox phaser 8560
Off the printer. Remove all the cables, wait 5 min and put cables back and restart it again.
or
remove the toner and put it back.
SOURCE: Xerox 7345 red comes out orange. Performed auto
the wrinkles sound like the fuser, how many copies on the machine? when was the last service? copiers are like cars they need to have there maitenance
Testimonial: "Exactly what the Tech. said when he arrived. Thank you. Great info, right on."
SOURCE: how to change ibt belt
The error code 004-346 is an IBT home position sensor. The belt may be damaged or didn't move.
The sensor which is mounted on the frame looks at the belt to see if it made a full rotation. Perhaps the sensor is dirty or damaged. Maybe the home reflective mark is damaged.
The belt may be damaged or shredded. Find out why the old belt was damaged before you install another part!
You probably need to purchase a new IBT belt PN 802K208991. The Xerox technician has a proprietary laptop to clear the codes and calibrate the "Belt Edge." The belt is very fragile, so whoever installs it needs to be very mehtodical and careful.
These may preclude you from repairing that yourself.
Whit
Item, Inc.
