Proscan PLT7223G-K 7in Android 4GB Tablet With Keyboard And Case Logo
Corey Mccoy Posted on Jan 21, 2015
How do i listen to messages recorded on my voice recorder
Josuey
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Jan 21, 2015
Josuey
Contributor
Level 1:
New Friend:
Answers
12
Questions
Helped
2209
Points
38
Lookup model number and go-to manufacturer website. Lookup FAQ ( frequently asked questions)
When playing videos on fb ,sometimes there is barely any sound other times it's ok
It is likely the video itself, if they did not record with proper audio settings you can only listen to what they used when they recorded the video.
Need help setting up voice mail now
Why doesn't anybody here ever say what the heck they are trying to work with?
Home recorder?
Cellphone VM
Comcast or AT&T VM
the VM system at your work?
This is like asking where is my car when we don't know what it is or where you are.
The key to getting good help is knowing how to ask a question.
3answers
Microphone on my iPad 3 with ios8 not working
Try recording using the voice memo to check the mic if you can then mic is working if not then either downgrade your ipsw to the previous firmware if you are sure it stopped working right after the software upgrade or replace the mic
My google voice search is not working! how do i fix that problem????
First tap on voice search option. Press on your manu button (or default start key) tap on setting > tap on phone search select your apps as u choice. Thanks
Is it better to download aiff files versus wav. files for the Ipad ...in live repro
If you use only apple devices to listen to your recordings, I would stay with aiff format. The .wav file format is more universally useable, but requires more memory.
1helpful
2answers
I have a Toshiba Portege M400. The problem is that when I go near the fron microphones I get a loud and wining feedback noise. Have you had this problem before? It seems strange. Can you help?
Turn the sensitivity down in the sound mixer?
Right hand mouse click on the loudspeaker icon and choose recording mixer. Adjust as required.
Hope that helps.
This is voice password and voice recorder
IF your voice is not being recognised , U can access to your system by installing another operating system in any other part of your computer through BIOS.
For this it is necessary that your BIOS must not be passward protected.
Once u get access to your system, u can make desired changes in settings to get rid of voice passward.
Toshiba Satellite 1905
First, try pluging in an exteral mic to check the mic itself is not broke. Next Go to the device manager to check for driver problems (control panel, system, Hardware look for yellow ?'s) Check control panel, Sounds and Audio, audio, sound recording, volume. There are just too many ways to mess with the sound settings, and they often seem to just mute themselves!
Good luck
Top Proscan Tablets & eReaders Experts
 Mikey
Mikey
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
