Tablets & eReaders Logo
j
jeffrey bauer Posted on Jan 21, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Get rid of dead robot - Tablets & eReaders
Christopher Goins
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 39 Answers
  • Posted on Jan 21, 2015
Christopher Goins
Expert
Level 2:
New Friend:
Greenhorn:
Answers
39
Questions
0
Helped
14218
Points
165
Try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Biggest tablet is frozen and only shows the robot. I have tried the methods suggested but I have no way of knowing if the tablet is on or off.
If there's a rotating yellow 3d mesh structure in the middle of the robot it's trying to update.
Make sure your charging and let it work. Leave it one hour...
1helpful
How Do I Reset an Idolian Studio 10 Tablet that is looping on the Android logo?
The robot dude meant it was loading up the system settings to the next screen so you can wipe off corrupted data that prevents the tablet from completing startup.usually an incomplete update.So
as follows ... Hold power button to switch off tablet....then hold power button and volume up together for at least ten seconds.let the robot appear and do nothing until the menu option comes up to ask you to factory restore.you will lose all your apps and data.if the robot comes on and gets stuck make sure the tablet is fully charged and repeat the two button hold as this may take several attempts.sometimes Chinese technology is unpredictable.
1helpful
My proscan tablet is locket and ican't unlocket it what can i do???
Since I don't know which exact Proscan Tablet you have, here is how to restore the PLT9045K.
1) Make sure the tablet is powered down.
2) Press and hold VOLUME UP(+) and DOWN(-) buttons, plus POWER button all at the same time.
3) Insert a metal pin in the RESET hole at the back of the tablet, then push and hold it for 2 seconds, while still holding the VOLUME and POWER buttons. Make sure the pin is pushed. It seems like nothing happened, but just keep on going to the next step.
4) Power ON the tablet and immediately, PRESS and RELEASE continuously the VOLUME UP(+) button in order to get the display as showing dead tablet (dead robot).
5) This is the critical part. Make sure you do the right sequence or you will start again from the beginning. Press and hold the POWER button, then press and release VOLUME UP(+), and the display will give you a screen showing different options.
6) Choose the option wipe data/factory reset, by clicking POWER button to scroll down. To execute the selected option, press VOLUME UP(+) button. The tablet will reboot back to its factory setting.
Screen galaxy tab 3 has black lines at top
You can not get rid of them. Take your tablet back to the stores, it has broken pixels, meaning that their are dead spots on your screen or a loose connection.
I have locked myself out of my tablet
You will need to do a factory reset:
1helpful
On my tablet the letter y and number 6 dont work
your touchscreen panel have been compromised, to get rid of that problem it should be replaced
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
