I tried to open the boiler and verify the status of the gasket. I don't how to verify if the gasket is in good shape. Also to confirm that all the screws were tighted.
I WOULD THINK THAT IF ALL THE SCREWS ARE TIGHT THEN YOU WOULD HAVE A BAD SEAL. THE GASKET COULD BE TO BIG OR TO SMALL IT COULD BE WOREN TO THIN IT COULD HAVE A VERY SMALL CRACK IN IT I WOULD GET A NEW GASKET AND PUT IT IN. BE CAREFULL NOT TO CROSS THREAD WHEN PUTTING BACK ON OR TO PINCH THE GASKET.
Testimonial: "Hi, Thanks for your fast response. Can you be more specific when you mentioned to "not cross thread". Also any suggestion where i can a replacement. I contacted the manufacturer and they no sell parts. The only provide services."
CROSS THREADING IS WHENN YOU CONECT ONE PART TO ANOTHER AT AN ANGEL AND TIGHTEN THIS CAUSES THE THREADS TO BE MESSED UP & CAN CAUSE A LEAK AS TO WHERE TO FIND PARTS DEPENDS ON HOW OLD IT IS WHAT BRAND IT IS SAY IF A DELTA YOU MAY HAVE TO FIND DELTA WEB SITE TO GET PARTS OR A DELTA DEALER. OR MOEN OR WHOM EVER.UNLESS YOU CAN GET LUCKY AND FIND THE WRIGHT PART AT A YARD SALE OF FLEA MARKET. IF YOU HAVE CROSS THREADED THE THREADS WILL NOT BE ABLE TO SEALCAUSING A LEAK.
