Comfort Zone CZ1500WC Infra-Red Utility/Portable Heater Logo
k
kumar Posted on Jan 21, 2015
Hi , I have a comfort zone heater. It was not working since yesterday. Front side power bulb is not glowing. Need help. Backside power red switch is glowing.
Winfield Adams
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 06, 2018
Winfield Adams
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
307
Points
Pulled side covers and followed the power to switch with small red button. Had power on 1 side none on other. Pressed little button and started working
5 Related Answers
Anonymous
  • 288 Answers
  • Posted on Nov 13, 2007
SOURCE: Quit working
Based on the limited info.I have, it sounds like the heating element is not getting power. suggest visually inspecting the switch and thermostat for burnt wires. Also check the heating element for broken electrode.
Just Add Tools
  • 7 Answers
  • Posted on Oct 02, 2010
SOURCE: change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
Anonymous
  • 13 Answers
  • Posted on Nov 29, 2010
SOURCE: my comfort zone heater wire element is glowing and
dust and dirty air can be one problem or some object has fallen in to it you may need to get it cleaned
Anonymous
  • Posted on Jan 14, 2011
SOURCE: how do you turn on
On the comfort zone CZ7007, the #1 rocker switch is for 600 watts, the #2 rocker switch is for 900 watts. If you flip 1 and 2 both to on you will get 1500 watts. Which is 600 and 900 added together. There is no down position, but only on and off.
Mack Baxter
  • 383 Answers
  • Posted on Jan 15, 2011
SOURCE: Is there a recall on
Have you tried resetting the unit?
just push and hold the two buttons on the right for 3 seconds and it will reset.
Or what are the problems you are having with them?
What lights are lit, etc.?
Tell us more--
Mack B
1helpful
2answers
I have a Comfort Zone fireplace heater model CZFP20M. The artificial flame stopped working. Is there a fuse inside? Anyone else have this problem? The heater still works btw.
It is possible that there is a fuse inside the Comfort Zone Fireplace Heater model # CZFP20M that has blown, causing the artificial flame to stop working. You should check the owner's manual or contact the manufacturer to determine if there is a fuse in the unit and where it is located. It's also possible that the artificial flame stopped working due to a malfunction in the control module or other electrical component. In this case, it's recommended to get the unit inspected by a professional technician.
It's not uncommon for artificial flames to stop working, it could be due to a variety of issues such as a malfunction in the control module, a blown fuse, or a problem with the artificial flame itself. I recommend checking the owner's manual or contacting the manufacturer for troubleshooting steps or to see if there have been any known issues with the model you have. If you are unable to find a resolution or the problem persist, it's always best to get the unit inspected by a professional technician.
Locating replacement quartz bulbs for comfort zone heater
To locate replacement quartz bulbs for your Comfort Zone heater, you can try the following steps:
  1. Check the manual: Your Comfort Zone heater should have come with a manual that includes information on replacement parts, including the type of bulbs needed. Check the manual to see if it specifies the type of quartz bulbs that are compatible with your heater.
  2. Check the label: Look for a label or sticker on the heater that lists the make and model number. This information can help you find the correct replacement bulbs.
  3. Contact the manufacturer: Comfort Zone is the manufacturer of the heater, so you can try contacting their customer service department to ask for assistance in finding replacement bulbs. They may be able to provide you with the specific bulbs you need, or they may direct you to an authorized dealer or retailer.
  4. Search online: You can also search online for replacement quartz bulbs that are compatible with your Comfort Zone heater. Try searching for the make and model number of your heater, along with the keywords "quartz bulbs" or "replacement bulbs."
It's important to note that if the halogen lamp is also not coming on, there may be an issue with the heater's electrical system. In this case, it may be best to contact a professional electrician or appliance repair technician to diagnose and fix the issue.
Comfort zone infrared heater runs for a few minutes a then completely shuts off
if unit runs ok for 3 to five minutes then completely shuts all power lamps off , then its hi temp limit sensor (safety) has been tripped , this usually goes out due to failure of main temp control , in point of fact contacts in temp switch literally weld them self's together and cant separate to allow heater to control temp
1helpful
Coils aren't glowing red
Most of the new heaters dont glow red. Its a safety thing so it dont catch your sheets or curtains,couch,chair etc on fire. Because of the idiots in this world we cant get a good heater anymore. Thats just the way it is.
1helpful
2answers
Comfort Zone CZ 1500 A04 CONTINUES TO COME ON
The AO4 is a board used by Earthwise on the Comfort Zone Heater. The reading is the board being used. If the heater just gives that reading it may need to be reset. This can be done by pressing up, down and enter at the same time. If this does not work unplug and try it again. Hope this helps
My comfort zone heater wire element is glowing and smoking
My comfort zone is not heating I had a infarared bulb that went out replace the bulb the heater still want come on it is hard to get techical support to tell what's wrong.
The bulbs on the older (pre-fall of 2010) Comfort zone heaters are in pairs... if one bulb of the pair is burnt out the other will not work. Also they are not easy to line up when replacing them back into the recepticle...they must line up perfectly to work.
1helpful
2answers
How do you turn on a comfort zone cz7007? has a knob that turns up to 7 and 2 red switches right next to each other.
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
