Acu-Rite Acurite Wireless Weather Thermometer 604 Logo
O
OLGA STOYKO Posted on Jan 20, 2015
How do I change the temperature to C?
Model 00827RX
How do you change the temperature on the window heating and air unit for model number f a z 1 2 hs2a
To change the temperature on the window heating and air unit for model number FAZ12HS2A, you will need to locate the thermostat. Depending on the model, this could be a digital or mechanical thermostat. If it is a digital thermostat, you will need to press the "Settings" button and use the "+" and "-" buttons to adjust the temperature. If it is a mechanical thermostat, you will need to rotate the dial to the desired temperature. Make sure to press the "Confirm" button to save your changes,
Temperature gauge not working after I changed my radiator?
Question edited for clarity and written English 'sense' to 'since', 'don't' to 'doesn't' etc.
Your coolant temperature sensor has likely failed if 'changed it' was the coolant temperature sensor and not the gauge. The scan tool gets the data from a few places as vehicles have more than one temperature sensor. The one on the radiator is the one that normally tells the ECM that the fan needs to run, but there is often another near the thermostat.
'year make model' as the first three words in every question please and placed in the correct 'make year model' category helps us to help you better. Every fault you could possible have can be found using Google 'year make model' (the problem)'.
https://www.google.com/search?q=2005+honda+civic+temperature+gauge+not+working
Model 7905321300 Kenmore stove bake button works can't adjust temperature
I am not going to look up your model. Are there two buttons..one to select bake and another to set temperature?...the latter does not work? If so, you have to replace the temperature setting unit/thermostat.
If the thermostat (sets the temperature) is part of the electronic board, the board has to be changed. You will have to open the top of the control panel to determine this.
3answers
How to change temperature scale?
What make and model device?
Or are you asking in general? To convert from C to F, multiply by 1.8 and add 32.
We cannot change the temperature of the freezer. Everything,even the water to the ice machine is so frozen (8*) that we cannot get ice. How do we change the temperature
I am not sure what model you have, but on my RF265AABP there are two buttons and digital displays at the top of the refrigerator, visible when the doors are open. One sets freezer temperature, the other refrigerator temperature. On my model if they read 88 88 with a blinking digit, it indicates a broken wire to a temperature sensor, usually the ice maker sensor since it tends to get snagged and damaged easily.
Cant change the temperature
What is the complete model number of the unit?
The oven temperature dial will not change the temperature it either will not change or only goes lower regardless of the direction you turn the dial
Bad t-stat. Go to any appliance parts site with model number and they will tell you what part is and cost. I would have done this but no model number to work with. Thanks and good luck
Mar 04, 2010 • Ovens
Frigidaire oven model FEB500CEBI TEMPERATURE PROBLEMS
The short and simple answer is yes you do.
Dec 13, 2008 • Ovens
1helpful
Manual or directions
We have the same model. From the manual:
STEP 1: Slide the system switch to the HEAT or COOL position to program the corresponding system
STEP 2: Press PROGRAM to enter program mode. Heat or cool will be displayed on the LCD.
STEP 3: Press the UP or DOWN arrow. The Program hour and AM or PM indicator are flashing. Press to change the hour.
STEP 4: Press PROGRAM to change to the minute position. The current minute will be flashing. Press the UP or DOWN arrow to change the minute.
STEP 5: Press PROGRAM to change to the program temperature. The current temperature will be flashing. Press the UP or DOWN arrow to change the temperature.
STEP 6: Press PROGRAM again to move to the next program number. Repeat Steps 3-5 to change the remaining Weekday and Weekend Programs. [there are a total of 8 programs]
After cycling through all 8 programs, press PROGRAM again to return the display to normal. Press HOLD/RET at any time to exit the Program Mode.
TEMPORARY MANUAL OVERRIDE:
To temporarily change the current set temperature without affecting your program:
  • Press either ARROW and hold for about 1 second to enter the Manual Override Mode. When display flashes, you can release the key.
  • Press the ARROW to change to your desired Temperature
  • Press HOLD/RET to return to normal mode, or wait 15 sections for it to return automatically.
  • The current program number will flash to signify the Temporary Overide.
  • At the next program change time, the Temporary Override is cancelled, and the next program temperature becomes the setpoint temperature.
Hope this is what you need. God Bless.
Top Acu-Rite Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
