Sewing Machines Logo
P
Patti sweetland Posted on Jan 20, 2015
My janome mb4 won'tt open designs I send from my computer. I have had machine for a year and never had this problem
Turning machine off and resending
martha greenanMartha Greenen
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jan 22, 2015
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
1690
Points
11
Make sure you r sending design in correct format from memory mb4 reads only .jef format
I want to find out how to see the stitch count or time my janome mb4. Has done?
Try page 24, although it may be referring to something else. Such information like hours used is only available to a technician using factory computer software.
https://www.janome.com/siteassets/support/manuals/embroidery-models/inst-book-mb-4en.pdf
Janome mb4 lost the bobbin thread but continued to keep sewing the design. I paused and rethreaded the bobbin. Do I have to start all over again? Can I go back to the point where it stop the stitches?
I`m confused whether you mean top bobbin or lower bobbin...You can go back to the point where it broke...Brother machines are far more simple when this happens...
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
2answers
Why does my Janome mb4 keeps shredding its top thread?
Change your needle and if it continues to happen, change the thread. Most likely your needle and thread are not compatible, ie the thread is too large for the needle's eye. Also, inexpensive thread will shred.
Tengo problemas con maquina de bordar janome mb4, me distorciona el bordado. I have problems with mb4 janome embroidery machine, embroidery distorts.
If your embroidery is distorted be sure you are using the right stabilizer for the fabric you are doing the embroidery on and enough for the density of the design.
I hope that helps.
Why does my Janome MB4 Jump in mid pattern and finishe 1" up or down?
This is usually caused by the y axis movement system. Occasionally this system can come out of sync, and cause the issue you described. Your y axis pulse motor may be going bad as well. In either case it would be best to take your machine to a Janome dealer for repair.
Janome mb4 embroidery machine-when carriage resets it goes all the way to the right
It sounds like your x-axis sensor is either broken or malfunctioning. When the machine initializes, this sensor tells the machine when it has reached the furthest point in it's range of motion. If it is not working properly, the carriage will extend past it's normal range, and stop when it physically cannot move any further. After a specified amount of time the x-axis motor shuts off, and an error message will appear. For a certain diagnosis and repair, it would be best to take your machine in to a Janome dealer.
Janometroubleshooting
checks that the strip wire and strip wire sensor, this worked well.
(the strip threads is the small spring by which you spend the thread to thread)
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
