This SC-320 code error occurs when polygon mirror motor fails or poor connection between BICU & polygon mirror motor please check first the connector of motor if you feel that the connector is good change the polygon mirroe motor it sits inside the LD unit please call the expert to change the part
thanks
sc541 means no warm up, press the clear modees the punch in107 then press and hold down the clear stop key untilk it goes into sevice mode then shut main power
Hello sir; According the menual said, that's thermister open or power supply board, but before go that far why don't try to do a reset, steps as follow;
Press "clear mode", "107", then pres and hold down "clear/stop" key, then choice "copier SP" then enter "5810" press enter, select 1, then press"R/#" key and "original type" key at same time to reset, try it and let me know the result. after reset just turn power off and back on.
