Its a rubber 1 inch ring
If you are going to replace the cylinder ring I would recommend getting the service kit (Part #18000) and replacing all the o-rings.
I'm assuming you have already taken it apart this far but if not:
Remove the 4 hex bolts on the cap and remove the head.
Using 2 of the bolts - thread them into the inserts on the top cylinder ring and use them to twist it off.
The cylinder and piston should 'pop' up under spring pressure from below.
Using an o-ring pick, remove the o-rings and thoroughly clean the tool - replace the o-rings and the bad cylinder ring. Lubricate the new rings with the grease provided and reassemble.
Hitachi NR83A 3 1 4 34 Full Head Nailer Parts
SOURCE: Hitachi NR83A air leak
Most all Hitachi nailers that use the plunger style of firing/safety mech will leak air past plunger (part #877-339) when firing, however should not leak when connected to air or resting. If air is leaking past plunger when connnected to air check following:
Remove head to reveal cylinder plate (part#877-318). Remove plate and check outer oring for nicks or broken. If nicked or broken, replace and problem solved. If in good condition, remove cylinder guide (part #877-310) and check two outer orings for nick /cut. Use caution when removing/installing cylinder guide. It is easy to pinch orings when installing causing air leak at plunger. If orings are in good shape then problem is warped body of gun not allowing outer orings to seal. To check for warped body, use the cylinder plate as a guage by lowering it into the area where the cylinder guide rests. Good Luck with your repair.
SOURCE: Hitachi nail gun nr83a 3 1\4. Broken driver
do you want to replace it man you need to put up more info if u do you can do it just take gun to hardware shop for parts it not hard to do
