Question about Nordic Track Nordictrack Exp 1000i Treadmill Rear Roller For Model Number Nttl09900
Why does treadmill powers up but belt wont move
    Novelist:
  • 145 Answers
Hi Janice, there can be a couple reasons. Does the console beep and act normal? Press start, do you hear any click from the controls below? Make n model of treadmill, any odd smells and safety key is in place? For control board services, Google treadmill analyzer and find the MCB List page, or contact Jatinah for repairs under 100 usually for most all control boards, including New Balance machines. Good luck !
Posted on Jan 21, 2015
    Top Expert:
  • 64,287 Answers
Try changing the speed .
Posted on Jan 20, 2015
SOURCE:
Matrix mx t4 treadmill
Maybe it has a tip over sensor and you set it off while moving it? Check your manual to see if it has one and how to reset it.
Jun 08, 2014 | Exercise & Fitness
Acd3 treadmill belt wont move
hi There.
A treadmill belt can shift to the right or left over time. If it shifts enough, this may cause the belt to stop moving. Stand at the back end of your machine and inspect the belt. If it has shifted, you will need to center it by turning the rear roller adjustment bolts. These bolts adjust both the tension and the centering of the belt. Follow the instructions in your owner's manual that explain which of the two bolts you need to tighten or loosen to shift the belt back to the center.
If the belt is too tight, it could cause enough tension that the motor can't turn the belt. This is most likely the cause of your belt not moving if you recently adjusted the belt tension due to slippage. Lift the edge of the belt. If you can't raise it at least 2 to 3 inches off the walking deck, the belt is too tight. Follow the directions in your owner's manual for loosening the belt. You will need an Allen wrench to loosen the rear roller adjustment bolts.
If the troubleshooting does not get the belt running again, you may have a tight motor belt or a bad motor. You will need to remove the motor hood to access these parts of your machine. If your treadmill is still under warranty, contact the manufacturer for a professional repair. You may void the warranty if you attempt to work on the motor yourself.
or read up some more at this link.
How to Fix Treadmill Belt That Won Move
or this one.
Acd3 treadmill belt wont move Google Search
Dec 16, 2017 | Exercise & Fitness
Incline and decline wont move, so the belt wont move either. Have a jazfit treadmill
1)LUBE THE DECK BELT, INMEDIATELY.
2) tES THE MOTOR INPUT VOLTAGE, IF THER ARE THE MOTOR NEED REPAIR.
3) tEST THE OUTPUT VOLTAGE BOARD, FOR INPUT VOLTAGE MOTOR, IF THERE ARE NOT THE BOARD IS FAULTY.
4) tRY TO RUN THE SOFTWARE CALIBRITATION.
SINCERELY.GOD BLESS YOU
May 08, 2012 | Exercise & Fitness
Treadmill will not come on
Watch this videos:
You must check the fuses+breaker inside from machine +breaker from house, of course check power cord if there are some loose cable, or another loose cable inside from the machine, or broken cable. Tight any cable inside.!
http://www.youtube.com/watch?v=N6Yg5S0WML8&NR=1
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
Oct 29, 2011 | Exercise & Fitness
My T81 treadmill quit working. All of the lights and bells and whistles all work but the belt doesnt move and the incline doesnt move. Ive only had it for about 2 years. It was working fine before I moved...
you need to check voltage going to the motors. no power ,the contoller board is not working. check the connections on the boardmake sure they are in all the way,also the power connections
Mar 17, 2011 | Horizon T91 Treadmill
Belt slipping and moving
Here is a basic procedure that will work for the majority of treadmills out in the market:
If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt clockwise, and the right bolt counterclockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centred. b. If the walking belt has shifted to the right, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt counterclockwise, and the right bolt clockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill
Jul 15, 2010 | Treadmill Doctor Weslo Cadence Dx10...
Weslo cadence treadmill wont work
I centered the belt on my tredmill and now it wont move at all. I tighted and loosened the belt. motor runs belt wont move
Feb 05, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Jan 25, 2010 | Horizon Exercise & Fitness
Manual Treadmills vs. Motorized Treadmills
Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Nordic Track Nordictrack Exp 1000i Treadmill Rear Roller For Model Number Nttl09900 Logo
247 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Treadmill Repairs...
Android Man
Android Man
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
