I was unable to get a code from auto zone,i wasnt sure of what i was looking for so i tried lefting each tire seperately with jack and then returning to ground . After riding around town i compared the height of the body of the vehicle above each tire to compare the distance,the front passenger side was higher then the other three
Hi luther.
not sure if this link will help you out but have a look.
Jaguar 2005 XJ XJ8 How do check for air suspension fault Google Search
SOURCE: 97 range rover air suspension problem
Yes, I have worked on these for years, the airshocks get old and seep,weather cracks and wear when they get bad they will burn up the pump, there are several solutions, I have removed the air valves and put stop leak in them and been able to get an extra year out of them, your best bet is to replace the air shocks before they burn your pump up. In my opinion.
