Aligned carousel changed all cartridges and drum CLEANING CYCLE
There are two ways to print black (grayscale) only. One is through the printer access provided through HP software. The other is through the Windows printer software. Try accessing through MS, such as printing from office or paint and see what the printer options show. Then try it again through another program, such as PDF Adobe, or another program that brings up the HP printer software. Another option is going through the device/printers option in control panel. Good luck.
SOURCE: HP 2210 xi printing problem - alignment
Try your question here http://www.techsupportforum.com/hardware-support/printer-support/49664-hp-psc-2210xi-problem.html
SOURCE: HP Photosmart 2610 printer - had been using the
Have you tried replacing the cartridges all together? That worked for me. I use HP 96 and 97 cartridges.
SOURCE: Hp color laserjet cp1215 is laying a shadow double
Press Menu button. Then press the <Left> scroll button and <Cancel> button simultaneously. This will take you to the secondory service menu. Press the menu button and select secondary service. Scroll through the menu item and you will see <Clean belt> option. Select it and press select again. This will clean the belt for you. Do it may be two or three times. This will solve your problem.
SOURCE: Black and color misaligned
u can try secondary service menu options. press menu then press cancel & left arrow simultaniously.now u can get a 2ndary service menu.
SOURCE: hp officejet 7310 won't print in black
You people are stupid! After the first person detailed the problem, why do you reiterate by saying "me too, me too"? People come here looking for answers, not more of the same. Here's a suggestion. If you don't have a solution, don't say anything!!!
