Are you sure of Wifi password is correct?
if so, 1st; try restarting your ipad by holding down power/sleep button untill it show "Slide to shut down" leave it off for 10 seconds & then re-open it.enter the Wifi -password, sometimes this step works.
2nd solution ; try resetting your iPad network settings, it will not affect your ipad in any thing except it will forget all entered passwords for any wifi you have already connected before. go to General from Setting, choose resett, and inside only reset network setting, shut down ipad & try to connect to the wifi again. Hope this solution work for you. Also you may try shutting down & opening your router again after 10 seconds while off. Good Luck.
If your WiFi is ON then the station ID should be showing when you look for a wifi signal with your tablet.
You should configure the Access Point with a new password and then attempt to log in with that new password.
You may need to uninstall the driver for the wifi on your tablet and re-install it using a new driver.
It sounds as if you simply need to reconnect to your wifi network. If you have already connected to it, but still have no access, then disconnect from your network, remove the network from your settings (Forget The Network) and then try reconnecting to it.
Hi there, you can reset your wifi device by holding Down something on the litle whole on the site, and if you tell me wich model i can tell you more about resetting
If you reset everything then you'll need to reconnect to the Internet by putting in your router password again. Go in settings and make sure you're not in airplane mode.
Please check your password and see the strength of the WI-Fi in your area. If this a wifi of your home wireless modem then check the modem and reset accordingly. switch off power for some time and restart. If not check your tablet on another wifi to confirm this or if the configuration has gone off from the settings. make sure that your password and the network is connected as seen on the lower taskbar .
Hi there. I noticed that sometimes Android devices seem to have trouble connecting to certain access points or.they seem to stop connecting alltoghether to certain routers. Sometimes this method can help:
Select the network you are trying to connect to and select "forget this network".
Reboot the tablet and try to reconnect again. Sometimes this doesn't work on the first try.
If that doesn't work I have heard of other fixes but they require "rooting" the tablet which could be potentiall dangerous.
Another thing you can try if that doesn't work is change the security to a different encryption type. Your password will either be WEP or WPA. Whatever it is try to change it to the other. I cannot give you detailed instructions on this because I don't know your router model or its current settings. Hopefully this helps and leave a comment if you have further questions. Good luck!
