Will your DF-5718 Motion Security Light accept LED, PAR 38 light bulbs, that are and approved for wet exterior use? The user manual seem to limit it to Halogen. If not, do you make a fixture with sim
I have heard that this fixture does not recommend LRD light bulbs. But the manual recommends PAR 38 bulbs, and my Home Depot store carries an LED bulb that is labeled as "PAR 38". Will this bulb work in the DF-5718 fixture?
The specific capabilities and settings of the PnP brand 30W motion sensor LED floodlight may vary depending on the model and design. However, in general, motion sensor LED floodlights are typically designed to operate based on detected motion and have a preset duration for illumination after motion is detected.
If you would like the PnP 30W motion sensor LED floodlight to remain on permanently, overriding the motion sensor function, you can try the following steps:
1. Locate the settings: Check if the floodlight has any accessible settings or switches that allow you to adjust its operation. This could be located on the fixture itself or on a separate control module if provided.
2. Disable or bypass the motion sensor: Look for an option to disable or bypass the motion sensor function. This might involve flipping a switch, pressing a button sequence, or adjusting a specific setting. Consult the product manual or contact the manufacturer's customer support for guidance on how to accomplish this for your specific model.
3. Connect the floodlight to a separate power source: If disabling the motion sensor function is not possible or practical, you can consider connecting the floodlight to a separate power source that provides constant power. This could involve bypassing the original wiring or using a separate switch or power outlet that remains on continuously.
It's important to note that overriding the motion sensor function may affect the energy efficiency and intended purpose of the floodlight. Motion sensor lights are typically designed to conserve energy by only activating when motion is detected, providing illumination when needed. Keeping the light on permanently may result in increased energy consumption and reduced bulb lifespan.
Always refer to the product manual or consult the manufacturer's instructions for the specific model of the PnP 30W motion sensor LED floodlight to ensure you understand its features and limitations.
The darker it gets, the brighter the lamp gets. If it's not getting bright enough at sunset or dawn, simply reduce the amount of light getting to the sensor.
Take a piece of black electrical tape, cut a hole in it, maybe 3/4 the size of the sensor opening, and place it over the opening. If that's too much effect, remove the tape, make the hole a little better, and re-apply it. If it's not enough, use a new piece of tape with a smaller hole.
My neighbor did this, over 30 years ago, after telling his kids they could play outdoors until the yard lamp came on.
I assume you mean that the light bulb is failing. This can be caused by a faulty connection at the base of the lamp which causes the bulb to heat at the connection point. Remove the bulb and (with power off!) examine and clean the bulb socket.
I am in the middle of a discussion with Heath/Zenith over a closely related and perhaps identical issue. I purchased their 5718 model from Home Depot and based on the fact that their brochure stated that "CFL bulbs are only usable on 270 degree units." I purchased the model 5718 unit (270 degree) and used CFL bulbs. It experienced the same problem others noted.
The technician at Heath/Zenith told me that only DIMMABLE CFL bulbs would work with this unit (even if the DualBrite feature is turned off). Standard CFL bulbs will not work.
Their brochure does not make that clear. Perhaps that is the answer to others' problems.
