I got a broken TV from a friend.
When I turn it on, I see mostly a white image and some movement (sound works perfectly fine).
I would say the image looks likea negative (black becomes white) and very bright, rather than solarized.
Would replacing T-Con be enough or should I buy a whole new main board?
T-Con:
http://www.shopjimmy.com/philips-996510009692-t-con-board-component-repair-kit.htm
Main board:
http://www.shopjimmy.com/polaroid-899-ke0-if3212xaph-main-board-for-3211-tlxb.htm
Or is it something else at all, like a power supply or a backlight inverter?
Do I need a solder iron to replace the T-Con? Main board seems easy to replace.
Thanks!
