99-02 Dodge Truck / 4.7L 70mm Power Plus Throttle Body Logo
Brent Stevens Posted on Jan 19, 2015
Drivers side tail light doesn't work, brake light works and bulb is good..
MARK GONZALEZ
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Jan 21, 2015
MARK GONZALEZ
Contributor
Level 1:
New Friend:
Answers
22
Questions
0
Helped
10380
Points
39
I did had the same problem on my chevy van
the problem was the wrong light bulb ,,
check if you have power in the sucket with a tester
if you do, buy new light bulbs make sure you get
the right ones ,, i did that n fix my problem ,, good
luck...
Brake light and tail light on driver side not working
First make sure you have voltage at the tail light connection. If you do then check to make sure you have a good ground. Make sure the connections are clean. Check to see if the bulb is bad. It might have a bad connection. If no power at tail light then follow the wire to see if there is a bad spot in it.
https://www.cruzetalk.com/threads/cruze-wiring-diagrams.86769/
Drivers side tail light not working
Put the passenger bulb in the drivers side and see what happens, if it works buy a new bulb.
When I attach a float to my ute I have indicators only but no brake or tail lights
Check all fuses under the dashboard, usually on the drivers side for any that are burnt out. The location of which fuse does what, like works the tail lights and brake lights should be clearly marked/printed on the board that conntains the fuses. Replace them if necessary. If that doesn't solve the problem, then check the actual bulbs behind the lenses to see if the 12 volt bulbs have burned out, and replace them if necessary.
1helpful
Tail lights work but not brake lights 93 toyota camry
The brake light side of the bulbs is powered by the brake switch and travels thru the turn signal switch.
If the third brake light works, I would guess the problem is in the turn signal switch.
1helpful
2answers
My tail lights are not working on my 2000 jetta the front lights work the break lights work and the blinkers work all inside lights work just fine
you need new bulbs in tail lights one bulb in each side has two elements one works brake other works running lights the elements in the bulb for tail lites are bad . so just replace bulbs. hope this helps.
1helpful
2answers
Driver side brake light is not working. Replaced bulb, but didn't need to it is the same bulb that works the tail lights, which still worked. Ugh, 2006 jeep liberty. Someone said it was a brake...
THAT RIGHT IF BRAKE SWITCH BAD NO BRAKE LIGHT WILL WORK.SPRAY ELECTRICAL CLEANER IN BULB SOCKET BULB SOCKET COULD HAVE OXIDATION AND CORROSSION CAUSING POOR CONTACT.
1helpful
Tail lights work but brake light doesn't. its the same bulb for tail and brake lights
Hi!
Maybe you have a problem with a brake switch or the bulbs. because the bulb has two heads in side one for the brakes and one for the tail lights. take the bulb out ad see if the both heads are ok and not broken, They are just tow springs. If they look ok,Then check the brake switch thats usually under brake pedal. Good luck
Any Thumbs Up would be appreciated.
Hell i just bought a chevy cavlier and my back break light is out...the light its self is on...its just the break light when pressed...
you don`t say if its both or just one brake light out.you say the light itself is on but not if you mean tail light or what.the tail lights use a different filament in the bulb than the signal light which is the same filament that the brake light uses.if the signal light work on the rear then the bulbs are good,if just one side works then the bulb is no good on the side that doesn`t work.if the signal lights work but neither brake light works then you need to check the fuses in the fuse panel under the dash on the drivers side.if the fuses are good then it will be either a bad wire at the brake switch or a bad brake light switch,this is located on the brake pedal lever under the dash.
2answers
Tail lights work on both sides. turn signal and
Sounds like you need to replace the drivers brake/tail light.
5helpful
2answers
Mazda 3 tail light on, brake light not on
The bulb actually has two seperate elements in it.
That is why the tail light works fine.
If you take the bulb out you will see the seperate elements.
Change the bulb and it should be fine.
Top Jeep Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Vehicle Part and Accessory Expert? Answer questions, earn points and help others
