I want to adjust the brewing temperature on my Cuisinart DCC-1200
Hello ditommm,
Not to worry, I think I can help. On the face of your DCC-1200, there are two black switches. The right one adjusts the carafe temperature. With the white line to the left you get a lower carafe temperature. With it all the way to the right you get the highest (hottest) temp. Of course, in the middle, you get a medium temp. I use mine with the lowest temp so that I don't end of scalding my lips and tongue when I drink my coffee. Use this bit of info to adjust your carafe temps. If you are looking to cause the actual brewing temp I don't know of a way to do that. Coffee needs to be brewed at the set temp in order to break down the elements of the ground coffee. I hope this is what you were looking for in an answer and that it is helpful. If it is, please consider leaving positve feedback for me. I will certainly appreciate it. Good luck! Regards, NormanZ
cuisinart dsc 1200 wont heat up
won't brew
