When I hit source button or input button, it takes me thru composite, s-vga, vga, component, etc. but does not stop on any of them and says no signal. I have a tuner/receiver to run it and other components thru but still no signal. HELP???? The # on my tv instructions is MK0-QS0059G000
SOURCE: RCA REMOTE CONTROL CODE FOR OLEVIA/SYNTAX 237 HD TV
Go to Best Buy and buy the DirectTV Universal Remote Control Model RC64 ($20). It will control all the functions on both the Olevia TV and the RCA Satellite box, except the A-B-C-D buttons for the User Guide. It's codes are:
Satellite Box - 00392
Olevia TV - 11610
Enjoy!
Nick from Ft Myers
SOURCE: QUESTION ABOUT PROGRAMMING CABLE REMOTE TO T.V
the code for olevia for cox cable is 1610. Hit tv then hold setup till light blinks twice. release setup. enter 1610 and wah lah
SOURCE: my olevia LT23HVX does not power on
If you want to see photos and a description of the disassembly process and commentary on my repair job, soldering in the new caps, etc. I've posted them online for anyone interested in tackling the job themselves. I've never cracked the case on a TV before, but thanks to some of the hints here, and some efficient Googling, I was able to fix my own set with a screwdriver, pliers and a cheap soldering iron, all for less than the price of a pizza.
http://www.flickr.com/photos/geegee123/sets/72157607269121264/
SOURCE: Using an HDMI cable on my 32
I would call Comcast...they seen more of this than I have
Sorry I couldnt help more w/o seeing it
SOURCE: On my Olevia 42
A Converter hdtv box... is the SOOLUTION!!! try it..youll see!!!
I had the same scan-turner problem with my Olevia "digital" Olevia tv!!
Because I was curious i tried that to see what happen..and it worked!!
Olevia tv fixed!!!
Easy..your tv is not able to scan cahnnels...then, the solution is to plugging "a thing" that can do that: a converter box.
