HP Photosmart C6380 All-In-One InkJet Printer Logo
M
Milagros Saltar Posted on Jan 19, 2015
What I can do with failure ink system?
Service EVMlFN08lAR
My 3210 shows Ink System Failure error what does that mean and how do I fix it?
hi there
we have one printer like that in our company and the problem is the same ink failure system i tried to check and clean the ink line but the problem is still the same, i try to bring it in hp service center and it is fixed but it willcharged you little bit high. try to unplug all the power from theprinter and also in the wall outklet and wait for sometime and plug it again. if the problem is still the same my advised is consult hp service center.
thanks
2answers
Ink failure ink system failure error oxc 18a0001
The "ink system failure" error is caused by air in the ink feed tubes. We have 2 articles posted on our web site giving step by step guides to purging the air from the tubes and clearing the error. You can find the articles at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
1helpful
Can't print on Photosmart 3110 all in one
This is a result in a print head failure or the use of non HP ink ether or there right you need to service the unit part will be needed if the maintance does fail. If your using non HP ink stop its use and purchase HP ink you be glad you did!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Panel says ink system failure. . . .error:0xc05d1381. what???
well this is the error that comes up in the display because of the ink system failure in the printer
follow the steps in the provided link -http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&product=439488&docname=c01458034
and after that the printer needs a service for the ink system
3helpful
Ink system failure Error: 0x05d1281
Ink system failures is a very serious problem on HP printer systems. Ifyou have this problem you should be ready to replace your printer.However there are still troubleshooting steps that you can do to try toresolve this problem. try this Ink System Failure Trouble shooting guide.
1helpful
Ink system failure
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Hp ink system failure
Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Ink system failure
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Wait two minutes.
13helpful
3answers
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
4helpful
5answers
Ink system failure
Turning the printer on and off will not solve your problem. If you get ink system failure you most likely have air in your ink system. This will happen after months of use -every ink cartridge you reload and purge will have a little bit of air trapped in it and over time it must add up. You have to do a system reset which causes your printer to start over and do a full purge of ink through your system. This is what happens when you do your first ink system set up when you open install new ink cartridges. To do a ink system reset you must first:
1. After your printer gives you a ink system failure you will need to press and hold down ok and cancel at the same time and then press the start button once. (make sure you hold the cancel and ok down until the system shuts down and then release).
2.Now (Again) hold the cancel and ok Button down and and press the on button again -making sure to keep holding down the cancel and ok until it shuts itself down again. It will seem like it is starting up again up will then just shut off. Now once it has shut off for the second time (It is VERY important that you have a new set of ink cartridges installed before turning on the system for the second time) This is because it will do a full ink purge and rid the trapped air in the system. If you have old ink in it or almost empty it will most likely not purge enough. A new set of ink works best- You can go back to your old ink after if you like and keep the "new" set for back up when the system fails again down the road (it will fail again -this is poor designing by HP).
3.Now once you have shut down the system and loaded a fresh set of ink (all 6 of the ink cartriges) you can now press the on button (at this time you should get a reset code the come on first and the printer will run its purging of the air and new ink.
4. You might have to do this more then once to rid all the air out of the system-keep trying and after 2 -3 times it will stop giving you the ink failure. I have fixed my printer many times by this fix for many years.
Good Luck!
k24674
Grand Canyon Tech
Grand Canyon Tech
