Konica Minolta Bizhub C224 Color Copier / Printer / Scanner Logo
f
faith Posted on Jan 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I with error C-DC30
Restart the System
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on May 21, 2015
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913691
Points
11960
Well you hit the "Jack Pot" That code means some one attempted to COUNTERFIET UNITED STATES currency!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!. Some one is in big trouble, There is not a thing you can do. You must get a KONICAMINOLTA Technician out to remove a special chip located inside the machine. It will be sent to KONICAMINOLTA then to the US SERECT SERVICE, since they protect US Money. Once a determination is made as to what happen. A new chip will be issued and new software will be up loaded. UNTIL THEN THERE IS NO RESET!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How to clear error code C-DC30 and C-DC10 on bizhub c452. Please assist. Thanks
CD030 and CD010 are both HDD (Hard disk errors) and cannot be reset by an end user (must use service mode for diagnostics). I am not finding C-DC codes you listed.
I have error code DC10 and DC30 on my konica minolta C452, I have changer the PWB, PRCB, black IU, but the error still persit, anyone with solution or suggestions?
You will need to contact Konica support directly in regards to this error. There is a part you need to replace "unknown in the service manual" that you can only get from them. Apparently these errors are caused when someone tries to copy protected currency. I have also read it might be cheaper to replace the machine rather than fix it.
Will a Canon Ax-dc30 fit the Powershot s120 ??
It does not appear to be compatible. See the list of supported cameras from the canon web site:
http://shop.usa.canon.com/shop/en/catalog/ac-adapter-kit-ack-dc30
2answers
I have a Dyson model DC30 which runs for a few seconds and then shuts off, is there a solution out there
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC30 seems to be working intermittently. In order to confirm which part may be at fault we'd need to take you through some simple diagnostic checks.
When you have your DC30 fully charged and near to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) so we can provide further assistance.
Windows driver 7 or XP
Contact Pinnacle's web page. You can download the latest drivers they have.
2answers
I own 15 garmin dc30 collars and when hunting they are spred out in no specific order over 3 astro 220 hand held units. I am having trouble receiving all of the collars. On one unit i may pick up for...
Hi, thanks for posting your Question..
At times you may experience Problems with a Garmin Astro DC30 Collar. I've heard And experienced reports of the following problems with Garmin DC 30 Collars
Before trying to do a Hard Reset for the Garmin Astro 220 DC30 Collar you should try and identify if it is the collar or the 220 Receiver. the easiest way you can do this is to check your Tracking System with another collar. If the second collar works fine then you can assume that you DC30 is not working as it should.
First i would Check all the basics, make sure the collar is charged.
I also would Delete and Re establish the Dog Collar in you system by going to the Dog List on the menu of the Astro 200, I would probably recommend Resetting the 220 receiver since it is much easier to reset that than the Collar.
Lastly, If these do not fix your problem you should try to "reset" the DC30 by
Removing the Back Plate (silver piece)
While Your looking at the connections for the two antennas, I would check to make sure there is nothing wrong with both the GPS antenna connection, and the VHF Antenna on the collar. Personally I carefully disconnect each and make sure they are both clean and free of Debris and Junk. (good Solid connection here will only help the performance of the collar) You can carefully use a brush or electronics contact cleaner for the VHF antenna (Screw mount) (See images below). I would not put anything into the SMP (square Antenna wire connector)
Removing the VHF Antenna on a DC30
Clean this before re-installing. Very Important to have a good Electrical connection3. Remove the Four Small Philips screws on the outside of the case to access the battery and electronics compartment. Very Carefully Disconnect the white battery connector from the board (see images below). Leave the battery Disconnected for about 15-20 minutes for a full reset, Reconnect it to the board.. (CAREFULLY) Here you Can see the battery Connector for the DC 30 Garmin
Different Angle of the connector for Dc30
As you re-assemble the Garmin DC30, Clean all seals and clean antenna connections.
Clean all seals and connections before re-assebling the Garmin DC30 collar
That is A Garmin DC30 Reset Instructions, and Many times when you are having Problems with Garmin DC30 collars this is the First step Garmin will ask you to do before sending them back.
Here is how to Mark a Location other than your location. For example You might want to mark the Tree before you get to it in case your dogs leave the tree. Most of the time If you are like myself You want to Scroll over and Hit the Mark Button, However that will just Mark Your current Location and not the location that your cursor is.
Here are the instructions To mark a location where your cursor is on your Astro 220.
Press map
Scroll the cursor over to the location you want to mark.
Press (ENTER) instead of pressing Mark.
If you press Mark it will mark your current location..
After you press enter.
It will either Select something that you've scrolled over and you should be able to save that as a Location, (Hint: you can change the name to what ever you want before you save it.)
Or if it doesn't select something it will say "no Map info at this point. Do You want to Mark a location here"
I know it's pretty confusing and counter intuitive, But that's how you can mark a location where you are not at.
If your Antenna's are not too OK,you can get a replacement from the below link:
http://garminastrodog.com/garmin-astro-dog-tracking-antenna-questions/
http://www.hdssupplies.com/garmin.html
Good luck and thanks for using fixya.
Where can I find a driver form my Miro Video DC30 graph card for Windows 7. Many Thanks, Jef
click start control panel administrive tools computer management device manager scoll to scroll to monitors + to expand plug and play monitor you might see a yellow question or exclamation mark ? or red x you will have to update the driver right click where you have options to update driver
if your computer came with a motherboard disk the drivers could be on it or you could download
cnetdownload.com on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need or major geeks download this graphics driver this will depend on your operating system
http://download.cnet.com/%7Bvalue=http://www.download.com/ati-catalyst-display-driver/3000-2108_4-10608736.html
This is a WHQL release from the Release 260 family of drivers. This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, and 400-series desktop GPUs as well as ION desktop GPUs. What
Driver windows7
Maybe, It doesn't work because the driver you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D julyallan01_25.jpg
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
