Technically yes you can, HOWEVER!! The 23x8's are taller, thinner tyres so they might affect your speedo reading and handling if they are not a standard Polaris size. The front end will also ride a tiny bit higher than the rear end. If you haven't got the original handbook try contacting Polaris directly or a dealer with your vehicles details and ask them what sizes are recommended for your ATV.
ATV tyre sizes translate as follows... a 23x8-10 tyre will be-
= 23 inches in diameter measured all the way across the widest part of the whole tyre.
= 8 inches across the width of the tread of the tyre.
= 10 inch diameter of the actual wheel rim.
22x11-10 is 22 inches tall, 11 inches wide on a 10 inch rim.
23x8-10 is 23 inches tall, 8 inches wide on a 10 inch rim.
Moving smoothly by maintaining an upright position, very few things are as charming and lucrative as it while standing on a kick scooter. It is harder in any case to find a scooter suitable for the guys who are taller in size. To stand quite straight on a kick scooter with a folding component that is healthy and strong, and feel physical relaxation and ease is an unquestionable requirement for the guys with a bulky body or taller figure.click here for more info Kick Scooters For Tall Riders
The only thing I could think of without hacking the seating area up is to, put some taller risers on your handle bars to raise them or buy a set of mini ape hangers. Mind you, if you go too Tall with the bars or real tall risers you may need to buy all new (Longer) cables for your controls. If it were me, I'd buy a bigger bike to fit my size and frame.
It is possible to make the task bar taller than it is by default, and this is the only way that I know of to change the size of the task bar, so I have to assume that you are asking how to take the task bar back down to the original "tallness." You would put your mouse cursor at the top of the task bar until it turns into a double-headed arrow, and then click down and drag the top edge toward the bottom of the screen until it is the normal height. If the task bar is locked, this cannot be done, so make sure it is unlocked by right-clicking on an empty spot on the task bar and make sure that "lock task bar" is not checked first.
So what does "different frame size" actually mean? And what does that frame size number, 13" or 25" or whatever, mean? It's fairly simple.
The frame size number comes from the length of the seat tube. The seat tube is that nearly vertical tube of the three big tubes that make up the "main triangle" of the bike frame. The seat tube has the bike's saddle attached at the top, and has the pedals and crank arms attached at the bottom. A short seat tube will make the pedals closer to the saddle; a long seat tube will make the pedals further away. The frame size number is the length from the center of the crank arm spindle (the axle that holds the two crank arms together) up to the top of the seat tube (where the saddle and seatpost are attached). On some bikes this is measured in inches, on others in centimeters.
But that's not the only dimension that changes for different frame sizes. As bicycle frames get taller, they also get longer. That means the distance from the saddle to the handlebars gets longer. This makes sense, since tall people don't just have longer legs than short people. They usually also have longer arms, a longer torso, and so on. So the bike frame also needs to get longer in every direction for a taller rider, not just longer from pedal to saddle. The top tube gets longer, which pushes the handlebars further away from the saddle. The head tube (the frame part that the fork attaches to) gets taller, so the handlebars will be higher up. All of these dimensions and more are fine tuned in every frame size, so the right size frame for a person's height fits well everywhere, not just in the saddle.
