Computers & Internet Logo
Anonymous Posted on Jan 18, 2015
User profile service failed log on.
Windows 7 home premium operating system.
How can I fix user login failed problem
You can try using the built in [hidden] Administrator account. first boot into safe mode then activate the Administrator account as shown here Windows 7 Built in Administrator Account Enable or Disable or here http://social.technet.microsoft.com/wiki/contents/articles/3040.enable-disable-the-local-hidden-built-in-administrator-account-in-windows-7.aspx. log into that account then go to control panel - user accounts and find your account and change your password then log out and try logging into your account with the new password.
1helpful
3answers
How to delete user account from Windows 7?
Try this.
1. Log in on a different account then the one your trying to delete. "The account must be a administrator account"
2. Click the start button then right click on computer and click properties
3. On the left side click advanced system settings
4. Under user profiles click settings.
5. Click the profile you wish to delete then click the delete button.
6answers
How fix computer sayin user profile cannot be loaded
Hi Anon
Please follow the instructions in the link below to fix your user profile problem.
When I try to log on I get a message that says, The User Profile Service service failed to log on. It also says , Profile can not be loaded. How do i fix this
Sounds like your getting logged into a temporary profile. To fix this do the following
  • Click the Window Button
  • type regedit and press enter
  • Navigate to HKEY_Local_Machine\Software\Microsoft\Windows NT\CurrentVersion\Profile Lists"
  • Click on each folder that starts out "S-" and look at the value for "ProfileImagePath" that has your username in it.
  • Once you have found your SID, on the left side right click your SID(S-...) and add a .bak to it
  • Exit regedit and reboot the computer and try and log in
  • This should recreate your SID for your user
If this is not the issue or you need further help please comment back.
5helpful
2answers
I have a laptop with preinstalled Windows Vista Home Premium which has worked well until today. I used it this morning but this afternoon I am unable to 'logon' after switching on the computer&...
I would like to introduce Windows Password Key 8.0 . it not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It creates a password recovery CD/DVD,USB Flash Drive for home, business and enterprise. It works perfectly to reset your Windows password. You can download it from http://www.lostwindowspassword.com
Dell computer less than 30 days old will not allow me to sign onto vista. error message says "User profile service service failed the logon. User profile cannot be loaded" What the heck do I do with...
Hmmm there could be a problem with the operating system itself. You can insert the disks the computer came with, and boot up to it. then when it comes to your install menu, select repair instead of new install.
Hope this helps
1helpful
User profile was not loaded correct
Log in as an administrator. Take backup of data in User profile. Delete this profiel by going to control panel---System---advanced tab--User profiles. Then try log in with username.
Unable to logon in to my system,it shows user profile not found.
Yes, use your installation disk (hopefully you have one), and run the repair utility.
The user profile service service has failed to log on
Start in safe mode as administrator.
Create a user profile
restart
use new profile
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
