Televison & Video Logo
P
Pat Simmonds Posted on Jan 18, 2015
Why wont my hitachi remote RC1205 work on my TV, I've changed the batteries
We've changed batteries. We view our TV through a hard drive box. When we record two channels we need to change onto the TV itself. So we need to press the av button and change to tv. We can no longer do this as the remote is not working.
Hitachi CLE 980 remote is not working. Wont turn the TV on no buttons are working. Have changed batteries still not working
Either the remote is fubar or the receiving circuits on tv are fubar. There is a way of checking a remote with a digital camera. - Google it and see what the story is.
TV remote won't work after changing batteries
When battery is changed, all the previous settings will be lost from the remote control. You should once again set it to your device, using codes.
Hitachi lamp timer
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
Iomega hard drive won't let me view files on my TV
I have suggestion for you please scan your external hard disk with a good antivirus and then anti malware bytes. Possible your problem will be solved. Thank you so much....
1helpful
My remote won't work and I used to be able to change the channel on the TV but even that dosn't work. I checked the cords. Changed the batteries;
Hello
First check its battery contacts for any rust or dirt accumulated on it. If so, contacts of battery will not touch properly, and the unit will fail to work. The second reason for malfunction is due to the infrared sensor inside your tV. If it is faulty, the set won't respond to infrared signal generated by the remote control. If so, eventhough remote control works properly, the set won't work with it.
Remote sensor comes just behind the infrared window at the bottom front panel of your TV. It is a replacable part and not so costly too. It is a three terninal component will look brownish black in colour. It will looke like this.
gopakumarg43_77.jpgThe procedure to check the remote control for its perfect working is described at a tip I've given and published by Fixya on Google. Type "gopakumarg43" on google search box, and get into my profiles. There you can see 'Tips and How To's" line, click on it. You can read it there. OK.
My TV remote control has stopped working. I've tried changing the batteries but it still doesn't work. Any tips or do I have to get a new one?
Check for rusted battery contacts due to leaked batteries. Clean them with polish paper or blade. Due to leaked batteries it is quite likely that the wires connecting remote control pcb & battery contacts are cut off.
sonsunny
2answers
My lifeStudio 1T external hardrive is not recognised by my computer anymore. when i plug it in the drive appears to start spinning but then makes to clicking noises and then a high-ish frequency beep....
I'm having these clicking noises aswell.
But mine still works.
Can you find the partitons tho ?
How to use Disk Management To start Disk Management:
  1. Log on as administrator or as a member of the Administrators group.
  2. Click Start, click Run, type compmgmt.msc, and then click OK.
  3. In the console tree, click Disk Management. The Disk Management window appears. Your disks and volumes appear in a graphical view and list view. To customize how you view your disks and volumes in the upper and lower panes of the window, point to Top or Bottom on the View menu, and then click the view that you want to use.
I've so.. its not broken.
Hello, I wanted to change the place of my TV. I am not sure if I plugged it correctly. I've got no power with hitachi flat screen spu42pt3. No green light. it is a flashing yellow light. I've...
If the tv was on when you unhooked it there is a cooling fan that didn't get to cool off the picture box and it has overheated and you will have to replace the box you can order it off of eBay it takes a few moments to replace it if you still have your owners manual it will tell you all about the lights on the front of your tv I've had to change mine out a few times hope this helps Merry Christmas
2answers
Remote for hitachi 52 inch projection tv not working
1st step, replace battery of remote, no result, 2nd step, check / replace Remote Sensor of TV.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
