SOURCE: CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done
The mamual says to hold the - and + volume keys at the same time for approx. 2 seconds till the light starts to flash green and red. The pairing code is 1234
SOURCE: how can i pair my samsung bluetooth headset to
turn off the head set then press and hold the on button until the blue light stays solid blue.
search for device on your new phone and add device code is 0000
SOURCE: My nokia E63 wont find bluetooth headset
I had a similar problem with my headset.. but found the solution.. I am using Jabra 2010.. ok.. so just switch "off" the headset...go to the pair menu on e63.. then switch on the headset.. and then look for new pair devices option.. voila it came up. hv been trying for almost 3 weeks before i got the sequence right.. somehow if u had switched the headset on beforehand.. it wouldnt recognise it only.. the solution is here at jabra website .. although.. they dont hv e63 listed .. but the same procedure for e71 worked fine for my handset..
