SOURCE: akai 32"
Well, sportbiff was on the right track, BUT there is a problem on taking the black mount off. it's really annoying and no one in my household can solve it. The mount just doesn't want to move further than a centimeter. I too would like to know the solution to this.
SOURCE: My tv Wont Turn On
My 32" hyundai LCD TV will not turn on. The power lead is ok the on / off switch on the side turns the red stand by light on and off. I am unable to get the LCD TV off stand by. I have tried the the stand by button and this does not do anything. Can anybody help.
SOURCE: CHILD LOCK
for the password type in all zeros unless youhave already set it then u must acess the service menu and reset everyting within there. how to access the service menu- power off, mute-1-8-2-power. if that code doesnt work let me know we can try another one
SOURCE: I have a 32" HD AKAI TV that keeps turning itself off
If the service shops didn't charge people $200 to fix this I would not post.. But since they do - here's the $8 fix.
If you are electronically inclined, replace the three 1000uf 16v
electrolytic capacitors in the power supply board located above the
power switch. They are likely bulging out at the top and failed. They
are the three in a row at the top - center of the board, located
between the two black heat sinks. Make sure you get caps rated for 105c
degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will
work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from
partsexpress or digikey or any good local electronics store. Your local
radio shack may have them but they won'y be 105c and thus may not last
long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
