Using the codes you can unlock your mobile because its safe for your mobile......Get the unlock code for your samsung SGH-M610 model mobile from this site Unlocking4u.com , here it gives the easy instructions to get the mobile unlocked.......
With the help of the codes you can unlock your mobile network , Get the network unlock code for your samsung mobile through this site Theunlockspot.com , it has the best instructions and simple methods for getting the unlock code for your mobile at a safe way........
You'll need to purchase an unlock code. You will probably find a number of companies via google a I have used a couple, which I'm not sure I'm allowed to post here so I recommend you visit Unlock-Zone.com, which is nearly perfect and they were recommended highly in the cell phone forums. Click the unlock your phone and select the mobile phone, current service provider to get the available unlocking service which ranges from $5 to about $25, depending on the model of phone you have.
The problem is either with the flex or there is a virus on the phone, that is why the screen comes up blue. The virus might have been contacted via bluetooth devices, mobile downloads or file transfers from laptops, also if the phone falls in water or placed on a hot object, the screen can be affected.
Try to get the appropriate software and cable then flash the phone first after flashing then you fix the flex.
i have this prolem too. i use a condemn battery, when the battery is full, network ok but when the battery started to less and little, limited service... i think you should replace the battery..
i have solution for that. using software SoftickPPP221 and uploader jad. u can see how it works in youtube. but then for samsung SGH-M610, it needs a java code such as #*5737425#(samsung D500). so all we need is java code to install games and application.
