Change cctv camera but still foggy
SOURCE: Image Backgound having horizontal lines
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your cameras warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
By the way, here's the info for India:
http://www.canon-asia.com/index.jsp?fuseaction=support&prod_type=image-phenomena_notice
http://www.canon-asia.com/index.jsp?fuseaction=contactus&prod_type=sales_service_in
SOURCE: blur images with nikon d200 camera
This could be a number of things:
1) Are you shooting at a fast enough speed, this then leads to what lens and how are you using it (handheld, tripod etc?)
2) The Lens you are using may need calibrating it may be rear or front focusing - it will focus slightly in front or behind your main subject
3) In camera sharpening isn't that great - all sharpening and if your shooting Raw files then about 70% of Raw files need sharpening should really be done in the post process
4) I used to have a lot of problems with soft focus and it ended up being down to technique, sometimes i focus in front then bring the subject back into focus from that point.
Otherwise if the problem just seems that the image is blurred it sounds like you may not be using a fast enough shutter speed.
Hope this is of help.
Drew
SOURCE: blurry images
it is possibly a CCD failure when it starts to fail it do like this as unable to focus the pics properly and the pics are blurry discolored and have different shades sometimes horizontal and vertical lines with white noise it is known problem in the cameras that were manufac in 2002 -2006 , all are repairing FREE OF COST just contact sony if u see one of the symptoms above explained , see th elink for support
http://esupport.sony.com/US/perl/model-news.pl?mdl=DSCP73&LOC=3
See this link for similar problems
http://www.imaging-resource.com/badccds.html
pls rate me FIXYA for help
It is possible that the image sensor which is the CCD- charge coupled device is faulty and will need a replacement. However it is important that the OE part is required and so is best to take consensus with Sony spares and service.
