Hi Esther, You will need to wipe all data and do a factory reset! To do this press the volume up key and the power on button at the same time until the screen lights up!
To see if it's simply stuck, hold Power and Volume Up for about 10 seconds, if nothing happens, it's completely out of juice.
If you haven't already tried a different USB charger than the one you've been trying, try a different one. I've had a charger or two die on me, causing me to panic, thinking my phone was unable to charge.
Aside from that, if nothing works, it sounds like your phone will need to go into the shop for maintenance.
Restarting or resetting your phone is a different thing.
Here is the process to hard reset:
1. Hold both the volume up key and the power key simultaneously for 5 seconds.
2. After your phone vibrates once, release the keys and let it power on.
As i am bit confused that you want to use t-mobile sim. What i can guess from your question is that you want to unlock your network, If that is the case then http://www.guaranteedunlock.com/ is the best choice or you can also try ImeiNetworkUnlock com these 2 companies are best in mobile unlocking.
solution 1, Hard Reset SONY XPERIA S LT26i with Software Menu :
Make sure the battery is charge properly
Turn on SONY XPERIA S smartphone
Don't forget to backup all important data
Go to menu: Setting > Backup & Reset > Factory Data Reset > Reset Phone
Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA S
The SONY XPERIA S will continue the step until ready to use in clean factory default.
solution 2, Hard Reset SONY XPERIA S LT26i with Flashtool applications:
Flashtool in the applications from Sony can be download from Sony website.
Flashtool software need to installed in you computer and ready with USB data cable
Make sure SONY XPERIA S battery is charge properly or full charge
Power off SONY XPERIA S
Boot SONY XPERIA S to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
Follow the menu at you computer display, it is easy to understand the steps.
solution 3, Hard Reset SONY XPERIA S LT26i with Hardware Key Button:
Make sure the battery fully charge
Do not forget to backup all important data
Turn off the SONY XPERIA S
Press and Hold together: Power Button + Volume Up Button for several seconds
Follow the menu at LCD screen to continue the hard reset SONY XPERIA S
Be careful before doing this step to master reset, because all important data and applications will be removed from SONY XPERIA S, we always suggest you backup all important data before performing the hard reset.
Try to flash your phone if it's out of warranty.There are a lot of softwares available. just google it using your mobile phone model. if it's on warranty ,take your phone to the customer care.
Please try this >Press and hold the 'Power' button and the 'Volume Up' button >Wait for around 5-10 seconds >Your device should then vibrate and reboot (hopefully) rectifying the teething troubles you were having!
First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Second Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
try to hold the beginning of the usb-cable on your mobile side upwards.. or downwards? if it works u know your usb cable or mobile plug-in isn't working so you have to buy a new usb-cable or you have to let your mobile fixed at the store.. if nothing happend: I DON'T KNOW.. but that's what happend to my SE X10
