No other issues. My other Rolex watch is not as difficult to operate the crown when setting the time.
SOURCE: seiko watch stuck crown
The crown maybe a screwdown type. Try unscrewing (like jar lid)them pulling out the crown.
SOURCE: I just bought a Mondaine
It seems like your watch has a little short stem and that's why it has only 2 positions. This does not affect battery in any way, nor the timekeeping.
The only downside of this is that you can accidentaly reset alarm time without knowing it as your watch crown is in permanent 1/2 way position.
If you are happy with that - keep your watch.
SOURCE: rolex watch yacht master set time
Let me start by saying that I own this watch and LOVE it!
To set the time you need to pull the crown all the way out to the furthest position.
To set the date you need to have the crown in the position in between the "winding" position and the "time set" position. Basically, pull the crown out till you hear/feel 1 click to wind, 2 clicks (total) to set the date, and 3 (total) clicks to set the time. I always set the date first to 1 day behind the current date. I then move the crown out to set the time so that I can set the watch to either AM/PM depending on the actual time. For example, I set my Rolex today (the 5th of January at 3pm - just an example). I would first move the crown to the date setting function and move it to January 4. I would then move it out one more position to set the time. I would go around the watch until the date changed to the 5th and then go around from 12 to 12 to change from AM to PM. I would then move it to the 3 and then I'm all set. This is helpful because it will ensure that your date will correctly change when the day changes and not be 12 hours behind.
SOURCE: I own a tag heuer
Yes it is correct as your watch has a counterclockwise crown forward setting direction. This is due to the specificaly layered lever and setting gear construction, so, nothing wrong with your watch.
Do not forget to rate, please.
SOURCE: Setting/operating Rolex Daytona
If you bought it at a market it is a fake watch, made in Far East country.
People who can afford to buy Rolex watch will NEVER sell it at a market.
All you can do is to find your nearest watch repair shop and ask at least to restart it. Do not expect even average timekeeping. The function buttons probably will not work as well.
Sell it, if you can and never buy watch at a market again.
