SOURCE: Need Insignia TV code for my Sony Receiver Universal Remote Control
Try This link it worked for me.
www.insignia-products.com/universalcontrolcodes.aspx
SOURCE: Code for cable TV remote - 26" Insignia 720p HDTV
I just bought a 32" Insignia NS-LCD32-09 using the Cox (suddenlink) remote and the code 0463 worked fantastically for me, Thanks!
SOURCE: Need Comcast Remote Code for Samsung LN32A330 TV
I contacted Comcast and here are your codes for the three way remote with DVR Samsung 10812, 10766, 10814. I have the same TV Samsung LN32A330 and it was the very first code for my TV! Hope this cuts down your frustration!
I have an insignia TV 32" and I used common code 10463 to program my direct tv remote. hope it works for you.
SOURCE: att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to [email protected], and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
