It means the washer makes an estimate of the size of the load, and can adjust the water level to suit, if you make that selection on the controls. Saves water use.
its normal for the new washers to sense how or what type of load you put in it , first thing after start is pressed , if it stays in sense! then it has detected a fault , either the sensor or the load is at fault , try the manual setting and see what it does
It means Load Ready, so... the machine has automatically sensed the laundry load to be dry enough to remove. Its calculated by the heating/cooling cycle times and will go into a cooldown mode before stopping.
1) this means overcurrent by the motor,the controller sense SUD detected. Indicating bad pump, or extra heavy load,excessive detergente, or SUDs. Press STOP/CANCEL for clear the display
That means "load error". You either have too large a load in your machine, or it's a very unbalanced load preventing the machine from spinning.
Either remove some of the load (especially any heavy items which have balled-up, or redistribute the load so that the weight is more evenly distributed.
If that fails you have a failure in the load sensing system and that can be anything from a sensor failure to a firmware bug or even a failed electronic component on the main circuit board. Unless you have substitute parts to hand, or specialist tools and the knowledge to use them correctly, that's the sort of repair best left to a professional.
As with all modern machines your senses the size of the load and adjusts water levels accordingly. Unlike older machines, this means that less water is used and less energy is used to heat excess water. It also means that you get a better wash as the cleaning quality is lower if the load is sloshing about in too much water.
EU --- error means ---Unbalanced load is sensed three times during a spin operation.to resolve the issue ----Open lid. Rebalance laundry load and close lid.· Check wiring harness · Check unbalance switch · Check circuit board
